Gauges
Old 05 May 2003, 02:36 am
Default Gauges
What gauges will I need before I get my manual boost control and what gauges are being used? [:I] I need to get my list together so I can clear it with my accountant (my wife).
Old 05 May 2003, 05:43 pm
Minimum would be a Vac/Boost guage Tee'd into the 11/32" brake booster hose coming out of the back of the intake manifold.
Autometer sells the guage and A-pillar pod
Pep-Boys has the Vacu-tite tees, elbow adapter, and hose.
I used:
Autometer Vac/Boost gauge - $50.00
Autometer Volts guage - $45.00
Autometer Dual guage pod from http://www.raceandstreet.com/ptindex
Hallman ES boost controller (Fixed by me) - $50.00
11/32" "Anti-smog" hose, Vacu-tite! universal tee, and a vac elbow from Pep Boys - $10.00
Double check that boost controller prior to install by blowing through the boost/pressure side whilst you adjust the knob.
Find right where it goess wide open and mark it with a sharpy/permanent marker and then test drive. Adjust using 1/8 turns or smaller and always lift the gas pedal quick if it zooms past 15PSI.
2003 PTCruiser GT
Mods:!Airbox silencers
K&N Filter(2153)
Autometer Pod - Boost/Vac and Volts
Hallman ES Boost Controller running 12PSI steady 14PSI peak
Old 06 May 2003, 03:50 am
Thanks Krieger [?] Did you install an aftermarket BOV that vents into the atmosphere? I read where if you increase your boost the stock BOV doesn't cut it.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 06 May 2003, 09:55 pm
No BOV installed just yet.
I have been keeping the boost just a little above stock so I don't see the need at the moment.
2003 PTCruiser GT
K&N Filter(2153)
Can you say Gauges! Wicked_PT General PT Cruiser Discussions 24 23 May 2009 06:15 pm
Stock Looking Gauges 2step Classifieds: For Sale/Trade 1 21 Sep 2005 01:23 pm
aftermarket gauges dfunkdj Turbo Performance 3 08 Jun 2004 10:40 am
Inferno Red airbag cover and gauges VAVROOM Classifieds: For Sale/Trade 0 11 May 2004 06:20 pm
Add-on Gauges Help 2K1Cruizer Tech & Performance Forum 2 03 Dec 2001 07:42 pm
