PT Cruiser Forum Car Videos
Car Rims
Spark Plug Gap
Old 05 May 2003, 11:29 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
Default Spark Plug Gap
Any thoughts? [:I]
http://www.srtforums.com/phpBB2/view...=asc&star t=0
Old 05 May 2003, 11:45 pm
cruisergeo cruisergeo is offline
[:I]'Bout What???
Cruisergeo
My Website is
http://cruisergeo.tripod.com/
Old 05 May 2003, 11:57 pm
GTPT GTPT is offline
Believe it's .048-.053
Old 06 May 2003, 11:41 am
About changing the gap after upping the boost. Makes sense to me...
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 06 May 2003, 01:50 pm
Dalite Dalite is offline
You may try as low as .042 according to other discussions of plug changes for turbo 2.4L in PT. Stay away from dual tip, splitfire, or non copper dual or triple electrode designs.
The #440 Copper Champion seems to be the most durable, and least like to cause detonation or "diesel effect" from too small of an electrode heating up enough to ignite fuel without a spark.
It also should be a little "colder", with the electrode more recessed, which, again is less likely to heat up to the point of misfire in a Turbo or Super Charged engine.
There was quite a bit of discussion on the PTCC site, and posts by MX-5 seemed to be very accurate in explaining the differences and what the outcome would be from different types of plugs.
Old 07 May 2003, 10:56 am
MX-5 MX-5 is offline
Thanks for the compliment!
Although I've been reading this forum for over a year, I didn't have anything to say until now.
I'm the guy who got the #7440 double platinums to market. I do not use them on any forced induction or NOS setup. Stay with the #440 standard copper plug. The 3032s are single platinum in a colder heat range.
Old 08 May 2003, 09:46 am
03baggedturbo 03baggedturbo is offline
Send a message via AIM to 03baggedturbo
talking to my turbo buddies they said that the stock plugs are usualy ok the way they are.. wires are the thing to upgrade.. but I dont know if the ones that come stock still work well after boost is turned up or not..
Old 08 May 2003, 10:19 am
When you are running a gap that is over .040 to .045, any plug failure is murder on the wires. Electronic ignitions are capable of producing so much spark to match the wider gaps, that plug misfire makes the cable the weakest link, by forcing it to carry higher energy than it is designed to carry other than for short durations. If you want the performance to stay at the top of it's game, you could consider changing the wires out to a larger core, and reducing the gap slightly...
Old 09 May 2003, 03:47 pm
Exhaust Depot Exhaust Depot is offline
Send a message via AIM to Exhaust Depot
A turbo car running .050 is pretty crazy. Once you raise your boost, you will have a higher chance of blowing out your spark at about 15psi or so. ON my surpa I would miss alot on high rpm high boost so i went from stock .043 to .032 and the car became a happy camper.
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
vB code is On
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
spark plugs ote69 Turbo Performance 24 12 Oct 2004 01:44 pm
Spark Plug Wires what should I do? KingKole02 Tech & Performance Forum 17 12 Jan 2004 11:06 am
  Secured Loans | Personal Loans | eHarmony Coupon | Debt Consolidation | Remortgage
