PT Cruiser Forum Car Videos
Custom Wheels
Computer wiring color codes
Old 06 May 2003, 09:11 am
Ian-PT-GT Ian-PT-GT is offline
Default Computer wiring color codes
I need your help to tackle my next secret project (more Boost performance, Coming soon).
I need the computer connectors wiring color-coding key, in order for me to tap into some circuits. Your help in this issue will be greatly appreciated with more power adjustments tricks![}]
Ian-PT-GT
Old 06 May 2003, 09:28 am
Dalite Dalite is offline
Ian,
Welcome back, we missed you.
The Wiring diagrams are scattered like the winds in the Service manual. Let us know which circuits, and maybe we can be a little quicker in getting you the info you need. The PCM uses up to 4 connectors. In you case (automatic) it will use all 4; each have 38 contacts, not all are used. If you will email me with a return emaill address, I will see if I can extract the info on the PCM connectors for you and make a .pdf file of them for you that I can attach to email.
Old 06 May 2003, 09:33 am
BTW, the quickest tricks to pull are to used resistance, zener diodes to ground or inline diodes to trick the PCM into believing it is getting cooler air, lower temps, etc.; to keep it from degrading performance.
Having said that, ground paths are critical on cars with the level of digital (especially CMOS) circuits as the GT has. If you decide to go the route of "altering" the sensor output, be sure to make all connections both solid and protected from the environment. A compromised ground can cause a "loop" that gets worse with each cycle; eventually resulting in a complete malfunction that may create an ASD (Auto Shut Down) of the circuit under "test".
Good luck, and keep us posted...
Old 06 May 2003, 01:48 pm
Art Vandelay Art Vandelay is offline
quote:Originally posted by Dalite
Ian,
Ahh...so that's why I have a 'missing' connector...my PT is a 5-speed. I wondered what was supposed to plug in there.
03 PT Cruiser GT 5-speed, Patriot Blue
95 Mustang GT-For sale
87 Shelby GLH-S #845
vB code is On
trailer hitch wiring barold Tech & Performance Forum 8 10 Jan 2008 01:42 am
Trailer wiring beelsamin General PT Cruiser Discussions 2 05 Jul 2006 06:50 pm
Computer Help?!!! jmack Non-PT Discussions 8 12 Jan 2005 01:57 am
reset computer onyx pt Turbo Performance 19 23 Aug 2004 09:06 pm
intake - must reset computer? got dyno numbers? secretspy Tech & Performance Forum 4 16 Jul 2003 06:22 pm
  Car Insurance | Free Advertising | Cheap Electricity | Mobile Phone | Presents Australia
