PT Cruiser Forum Car Videos
Custom Wheels
PLASTIC GT MANIFOLD PROBLEMS?
  #11 (permalink)
Old 19 Sep 2005, 05:22 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
the miss is not there at wot or 3/4 throttle, its only present at low rpms like just giving it enough gas to maintain speed like at about 25mph or so. The car is running too lean i think at lower rpms causing the tach to bounce a little and have a miss. Probably going to get a dtec fuel computer and create new fuel maps.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
  #12 (permalink)
Old 19 Sep 2005, 05:41 pm
Herschel Herschel is offline
Send a message via AIM to Herschel
Why don't you just read the coloring on the spark plugs?[:I]
  #13 (permalink)
Old 19 Sep 2005, 08:03 pm
My spark plugs used to be brown and burnt a lot when i was running really pig rich. I haven't checked them out lately since the install of the manifold. I do so much mixed driving though throughout the rpm band its hard to tell if i am running rich or lean now.
  #14 (permalink)
Old 20 Sep 2005, 03:01 pm
Cal Cruzer Cal Cruzer is offline
The PCM should correct for any lean/rich coditions within it's programming parameters, especially with stage 1. You should not be lean outside of parameters until the injector reaches 100% duty cylce. We should not even be close to that without extensive mods that would create a need for a lot more fuel flow. S1 does run leaner than stage 0 but those are the programmed parameters.
  #15 (permalink)
Old 22 Sep 2005, 10:44 pm
purplept purplept is offline
I also installed the plastic intake manifold and noticed better torque and better high rpm power. I think it's well worth the investment. However, my car runs much richer now, you can really smell it when at idle. Maybe that's because I have the Maxxfab downpipe w/o cat?
[IMG]|2003 PT GT 5-Speed | Mopar Stage 1 | Mopar 2.5\" Dual Exhaust | Mopar Short-Throw Shifter | Mopar HO Plastic Intake | Mopar Boost Gauge | AGP WGA/BOP | APC Carbon Fiber Taillights | Axis 19x8 Wheels/Yokohama 225/35ZR19 Parada Spec2 Tires | BTG Strut Tower Brace | BTG Billet Shorty Antenna | Eibach Anti-Sway Bars | HKS SSQV BOV | JLM Motor/Tranny Mounts | KW Variant 1 Coilovers | Maxxfab 3\" Downpipe | NGK Iridiums | Prototypepower UCP/CAI v5 | PTeazer Smoothie Roll Pan | Screamin\' Demon Coil/Livewires | StopTech Slotted Rotors/Hawk HPS Pads/Stainless Steel Lines | Unorthodox Racing Underdrive Pulley|
  #16 (permalink)
Old 23 Sep 2005, 12:03 pm
blackboosty blackboosty is offline
No problems with my plastic manifold. Threw a code the first time I started it, but that was my fault, had a sensor unplugged. Definite increase in topend, throatier sound, overall, a nice mod.
me
  #17 (permalink)
Old 23 Sep 2005, 03:53 pm
ValAir ValAir is offline
I installed the plastic intake at the same time I put in the S1 kit so all I feel right now is power. The only thing that I didn't like about the plastic intake is having to loosen it up in order to get to my second spark plug.
\'03 GT Black, 5 speed, Chrysler/Borla dual exhaust, Chysler performance air filter, Stage 1 kit, Plastic Intake, Chrysler B.O.V.,
Magnecore wires.
  #18 (permalink)
Old 23 Sep 2005, 07:51 pm
SuGamer SuGamer is offline
I don't understand why. [:I] The plastic manifold flows better, making the car run slighty leaner thus part of the power increase.
  #19 (permalink)
Old 23 Sep 2005, 09:36 pm
its not the manifold, its the downpipe and no cat. Guaranteed. [?]
  #20 (permalink)
Old 25 Sep 2005, 12:33 pm
littleblueGT littleblueGT is offline
Does the manifold come with all the "o" rings and gaskets needed for installation? (throttle body gasket, lower manifold to head, "o"rings between upper and lower manifold) Is there a noticable difference in performance in hot weather and stop and go driving conditions due to less heat soak? Is everyone having trouble removing #2 spark plug?
vB code is On
Turbo plastic manifold on N/A PT? littleblueGT Tech & Performance Forum 4 24 Jan 2007 01:05 pm
Plastic Manifold in Summer? littleblueGT General Turbo Discussions 4 22 Jun 2006 10:10 pm
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
Plastic manifold & plugs quicksilverdon General Turbo Discussions 3 21 Mar 2006 12:48 pm
Plastic PT Cruiser Intake Manifold Kit hangtym3 General Turbo Discussions 59 11 Aug 2005 09:10 pm
  Personal Loans | Buy Anything On eBay | Debt Consolidation | Boston Moving Company | Car Credit
