PLASTIC GT MANIFOLD PROBLEMS?
  #21 (permalink)
Old 25 Sep 2005, 03:56 pm
quote:Originally posted by littleblueGT
Does the manifold come with all the "o" rings and gaskets needed for installation? (throttle body gasket, lower manifold to head, "o"rings between upper and lower manifold) Is there a noticable difference in performance in hot weather and stop and go driving conditions due to less heat soak? Is everyone having trouble removing #2 spark plug?
yes.
yes.
and yes.
  #22 (permalink)
Old 25 Sep 2005, 06:56 pm
quote:
I don't understand why. [:I] The plastic manifold flows better, making the car run slighty leaner thus part of the power increase.
The car wouldn't run leaner under normal conditions since the sensors are sampling data multiple times per second and the PCM is making decisions about AF ratio accordingly. This keeps it within programmed target AF. The only time it MIGHT be a little leaner is under WOT when the PCM is using a lookup table instead of sensor input for this. However WOT is purposely somewhat richer for this reason.
  #23 (permalink)
Old 10 Oct 2005, 10:50 pm
Does anyone know if the plastic manifold use different bolts than the stock (aluminum) manifold?
<font color=\"navy\"> <b>
2004 Dream Cruiser</b>
Best ET : 14.1 @ 98 MPH [Automatic]
Mopar Stage 1, Mopar 2.5\" Exhaust, Mopar BOV, Mopar/KW Variant 3 Coilovers, Eibach Sway Bars, 225/45/17 Goodyear GSD3 Tires, MPSC Rotors, Hawk HPS Pads, PTeazer Rollpan, \'06 Taillights, Mopar Navigation and Subwoofer</font id=\"navy\">
<font color=\"red\"> <b>2005 Crossfire SRT-6 </b>
Best ET : 13.4 @ 108 MPH
</font id=\"red\">
  #24 (permalink)
Old 11 Oct 2005, 12:19 am
Send a message via AIM to AZ_IceMan
Yes, the bolts are very different, you will need all new bolts, i did not reuse a single one.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
  #25 (permalink)
Old 13 Oct 2005, 06:09 am
If you puchase the plastic manifold kit from Tommy at www.haynesspeedshop.com you get the proper bolts with the kit.
Deen
  #26 (permalink)
Old 26 Oct 2005, 01:41 pm
Send a message via AIM to CruiserDan
will these new manifolds or even the old gt metal manifolds work with an N/A pt
<font color=\"blue\">Patriot Blue</font id=\"blue\"> 02 5-Spd
  #27 (permalink)
Old 26 Oct 2005, 04:19 pm
Send a message via AIM to 13secPTCruiser
i heard that they work... only a little bit of tweaking
  #28 (permalink)
Old 28 Oct 2005, 10:14 pm
quote:Originally posted by Nudle
[^]I replaced the manifold with the plactic one & also installed a new set of NGK platiums and I can definely notice and increase in porformance,gaped the plugs at 32 and no miss. My wife who is no speed demon even noticed a diffrince. I can say WOW! what an improvement.[^]
i think you're not supposed to use platinums? with a boosted engine for spark reasons. Something about spark blowout or sumtin. SuGamer where are you! Help me out here [|)]
  #29 (permalink)
Old 25 Mar 2011, 03:59 pm
JaviPTGT's Avatar
Send a message via Yahoo to JaviPTGT
Default Re: PLASTIC GT MANIFOLD PROBLEMS?
hey i want to get one for mine 03 GT where can i get one or does anyone have one for sell
  #30 (permalink)
Old 25 Mar 2011, 05:39 pm
Kawizx9r's Avatar
Revived thread!!!111
Dealership will have it and it's affordable as hell. That or look for a late 2005 and up wrecked PT GT at a local pick n pull and yank it out.
RX-7 FD3S Twin turbo
- Going single big turbo soon
Turbo plastic manifold on N/A PT? littleblueGT Tech & Performance Forum 4 24 Jan 2007 01:05 pm
Plastic Manifold in Summer? littleblueGT General Turbo Discussions 4 22 Jun 2006 10:10 pm
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
Plastic manifold & plugs quicksilverdon General Turbo Discussions 3 21 Mar 2006 12:48 pm
Plastic PT Cruiser Intake Manifold Kit hangtym3 General Turbo Discussions 59 11 Aug 2005 09:10 pm
