...high RPM miss???
  #31 (permalink)
Old 09 Aug 2003, 01:47 am
It may be a coincidence but...my fix came at the same time the Stage 1 PCM's started to ship!
  #32 (permalink)
Old 09 Aug 2003, 03:36 pm
I too have this boggle.
I went to my local dealer this morning (8-9-03) and found that they do not know of this issue.
So I brought them up to speed on it.
They said they would call Chrysler, and get back to me.
I got the ball rolling on this... but the TSB from Grandgrandpa, is what I need.
Please post it when you get it Grandgrandpa.
Thanks in advance.
Harquin
Black 03 Turbo
\"Pirate Harley Cruiser\"
Mopar Stage 1 and BOV
Autometer Gauges in Triple Pod
Custom Emblems
Custom Switch Plate
AirRaid CAI
Chrome Gauge Eyelids
FlameBall Shift Knob
BTG Strut Tower Brace
Dual Battery System
12 inch Black Shorty Antenna
Working on Custom Audiobahn System
Coming SoonÂ…
Eibach Springs and Sway Bars.
Plenty of Neon
  #33 (permalink)
Old 11 Aug 2003, 09:09 pm
Here it is: TSB# 18-029-03
Date: August 8, 2003
Subject: Slight Engine Misfire Above 5200 RPM
PM me if you need more info.
  #34 (permalink)
Old 11 Aug 2003, 09:18 pm
Romli... You Rock Bro![8D]
This is what I needed!!!!!!!!
Black 03 Turbo
Custom Emblems
Custom Switch Plate
AirRaid CAI
Dual Battery System
Coming SoonÂ…
Plenty of Neon
  #35 (permalink)
Old 12 Aug 2003, 11:52 am
I checked with my dealer and the TSB number posted yesterday is not the fix for surging. The TSB given yesterday I believe is for the clean up of the waste gate. The TSB to fix the 5000-6000 RPM surge will include a PCM replacement. So ask the dealer if he is replacing the PCM.
  #36 (permalink)
Old 12 Aug 2003, 08:43 pm
Here's a little more info for the non-believer(s)
TSB# 18-029-03
SUBJECT: Slight Engine Mis-Fire Above 5200 rpm
OVERVIEW: This bulletin involves replacing the Powertrain Control Module (PCM).
MODELS: 2003 (PT) Chrysler PT Cruiser
NOTE: This bulletin applies to vehicles built prior to January 22, 2003 (MDH0122xx) equipped with a 2.4L Turbo engine and manual transmission or prior to March 18, 2003 (MDH 0318xx) for vehicles equipped with a 2.4L Turbo engine and automatic transmission.
SYMPTOM/CONDITION: Vehicle operator may describe a random or slight engine mis-fire when operating vehicle above 5200 rpm.
  #37 (permalink)
Old 14 Aug 2003, 08:39 pm
Thats correct, have mine on order.
Don
\'03 Inferno Red 5 spd. Hurst shifter,Loaded
  #38 (permalink)
Old 17 Aug 2003, 06:37 pm
I stand corrected...sorry. The PCM replacement makes the car drive the way it should.
  #39 (permalink)
Old 18 Aug 2003, 09:32 pm
It's hard to say...it's very smooth and the car does drive different but I had the high RPM problem since new(3100 miles now)so I am hoping this is normal. The PCM fix has finally given me a consistent test bed. While searching for the RPM mis-fire the one thing that produced a noticeable change was the re-gapping of the plugs to .040. I will try the 7440 DPP Champions because of that experience. I will try them at the recommended .050 gap then down to .040. I have priced the plugs at a couple of stores and most sell them for $4.29 each.
high rpm miss 1quickpt Turbo Performance 24 17 Mar 2007 06:54 pm
high rpm miss gone tthrift Turbo Performance 8 06 Oct 2003 07:39 pm
High RPM Miss Mean Green Turbo Performance 4 27 Jul 2003 10:46 pm
High RPM miss Lee01 Turbo Performance 23 30 Jun 2003 08:25 pm
High RPM Miss potential Fix Exhaust Depot Turbo Performance 11 15 May 2003 06:31 pm
