Lower center console gauge install
Old 12 May 2003, 04:48 pm
Default Lower center console gauge install
Here's 3 pics of my lower console gauges .
Old 12 May 2003, 04:52 pm
In the first pic it shows how it is fitted in lower cubby hole. The second pic showes how much of the 3 gauge pod I had to remove to fit it into the cubbyhole. The last pic shows the velco and the back side of the gauges. All gauges and pods were purchased from Race & Street . The installation of the gauges was performed by Henry's Garage in PA . I did the modifications to make it fit into the cubbyhole.
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 12 May 2003, 05:05 pm
Could i see it completed?
Set the geere shift for the high gear of your soul!!!
http://interactive.colum.edu/students/jsoltes/IMP/projects/project%201/ptperform.html
Old 12 May 2003, 05:18 pm
The first picture shows the completed setup for ,now. I'm leaving that pod black cause it flows color-wise with the radio and swithches above. I could remove the remainder of the pod and completely recess the gauges into the cubbyhole,however then the gauges aren't visible when driving. I got a problem with the fuel pressure gauge presently and therefore haven't used anything more permanent to attach the pod . I'm unsure if I will mount brackets or not !
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
Removing Lower Center Console CHROMEDCRUISER Interior Accessories Forum 3 03 Jan 2005 10:27 am
Body Colored Center Dash Console patbluecruiser Interior Accessories Forum 20 05 Jun 2004 08:27 am
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
Install of Water Temp Gauge jramosGT Turbo Performance 6 18 Apr 2003 03:35 am
