PT Cruiser Forum Car Videos
Car Rims
5spd turbo Throttle Body upgrade
  #11 (permalink)
Old 03 Dec 2005, 08:05 pm
12secondPT 12secondPT is offline
quote:Originally posted by Cal Cruzer
quote:Originally posted by Topless in Cali
Just make sure you put in the sensors from the 5spd otherwise it will throw codes. It makes [8)]
Did you have to calibrate the TPS when you switched it over to the new TB or is it a one position installation?
you would not have to caliberate it one way install. if your get on that comes wiht the sensors on it you don't have to switch them over. he had to because he had a bad one on the new t-body
  #12 (permalink)
Old 04 Dec 2005, 05:27 pm
Topless in Cali Topless in Cali is offline
I would just reset the PCM if you get one with good sensors. Although I still would suggest switching them just too make sure you've got good working sensors especially if the TB comes from a junk yard and it is an older part than the one currently on your car. Also if your PT does not have many miles like mine (10K) I perfer to have the newest electrical parts on it just for longevity sake.
12 second- Thanks for the posting of the square mm #'s. It really does show a substantial gain in air volume and flow!
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
  #13 (permalink)
Old 06 Dec 2005, 12:02 pm
Wicked_PT Wicked_PT is offline
let me look at my post of yeah it says "i'm making a custom intake manifold that will run a t-body off a mustang." sounds like i got it covered on all the bases the manifold will be ported and it will have a custon plenum.
Sorry, I didn't realize you said that. Cool!
  #14 (permalink)
Old 06 Dec 2005, 09:51 pm
no problem but it will be a little bit before it happenes. kinda cold here
vB code is On
AT Throttle Body in 5 Speed mvandale Turbo Performance 3 05 Dec 2006 12:03 am
POWERAID Throttle Body Spacer - Works?? matt87951 Tech & Performance Forum 17 23 Aug 2006 09:35 pm
Airaid Airmax and throttle body spacers Robster Tech & Performance Forum 22 22 Jul 2004 08:12 pm
Throttle body spacer for turbo? gt_tuner Turbo Performance 1 14 Jul 2004 10:02 am
Throttle Body Spacer PT-ERA Tech & Performance Forum 19 06 Jan 2004 03:06 pm
  Cheap Loan | Advertising | Remortgages | Loans | Credit Counseling
