5spd turbo Throttle Body upgrade
Like Tree9Likes
  #21 (permalink)
Old 09 Feb 2017, 09:23 am
Default Re: 5spd turbo Throttle Body upgrade
I will post a picture of mine from my 03 GT/DC2 5spd. I have the intake removed already since I am upgrading, in my opinion, to the composite intake. I am actually curious as to what it is. I had read about the apparently smaller throttle body on the manual cars, but never bothered to actually see if it is true. I will go out and get it from the garage shortly. It's -16 outside so I am not motivated at this instant!
  #22 (permalink)
Old 09 Feb 2017, 11:00 am
ROLMAO....
Sometime I think some members just do things out of stubbornness?
I suppose some have never read Chrysler sales brochures either?
The manual throttle body because of the compensator attached to the throttle plate total flow rate is less than that of the throttle body without it. The automatics as far as normally should have been assigned to the engines during the production run should be a throttle body not having the compensator attached to the throttle plate.
  #23 (permalink)
Old 09 Feb 2017, 11:37 am
Manual throttle body air flow compensator attached to the throttle plate
As with many PT Cruiser production line changes not all manual transmission equipped PT Cruisers had these special Throttle bodys.
  #24 (permalink)
Old 09 Feb 2017, 12:09 pm
wingman55's Avatar
OK, enlighten me. Is the black semicircle thing in the photo the compensator? What exactly does it do? I don't know much about throttle design.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
  #25 (permalink)
Old 09 Feb 2017, 12:52 pm
During shifting it helps to increase the air flow speed slightly to smooth out the air velocity and somewhat maintaining the AFR range which changes when you let off the throttle to shift and than reapply the throttle. You don't do that with an automatic so the compensator is not needed. The compensator in other words helps increase the creature comfort driving a PT cruiser.
During the first couple years Chrysler sent out questionnaires to random owners to get an idea of complaints,compliments or improvement suggestions. Drivability was one thing that seems to be mentioned the most needing improvements.
wingman55 likes this.
  #26 (permalink)
Old 10 Feb 2017, 06:34 pm
Wow, for once you actually posted some good info instead of passing off your opinion as fact!
In your picture above, the inlet appears to have been ported, probably making the effect of the so-called "compensator" negligible and simply an obstruction at this point.
One of my 03 GT/DC2 5spd does, in fact, have that "compensator". I wonder if the other two have them also.
The pictures below show mine. It is indeed 52mm on the output, probably as the number stamped into the throttle blade indicates. I was surprised that the inlet actually necks down to approx. 46.5mm just before the throttle blade. I wonder if the automatics also neck down to this degree too. My parts car is an 03 GT automatic so I guess I will go out and give it a measure tomorrow.
  #27 (permalink)
Old 10 Feb 2017, 06:50 pm
As it is on most forum if I post something that is not known group authored and perpetuated information readily found internet presumed empirical information it must only be my opinion because I do not present my research data! Comments generally negative in nature, not saying yours was, directed about my responses I post without me saying either IMO or IMHO also tells me who really know things and who is a internet warrior!
The picture was a stock TB rebuilt and some "paza" fun machining to make it look Hyper performance in the style of most "ricer" parts.
My other TB with the compensator has been sitting on the outside in the parts to go pyle and looked waaaaay worse than yours pictured. I just really need to make a garbage run!
BTW Good pictures posted for this thread.
  #28 (permalink)
Old 12 Feb 2017, 11:41 am
rob302's Avatar
Originally Posted by Fk5 View Post
....I took the throttle body with the intake that I pulled from an auto turbo PT in the yard. I think it was an '04. It had an aluminum manifold. When got home, the throttle body was the same as my 5 speed. I believe they were both 52mm IIRC. It is my belief that ALL turbo cars and auto NA cars have the larger throttle body. I think only the NA stick cars have 46mm.
so we have two different 5 speed 03 GT's, with two different throttle bodies.
WHY?
  • was FK5's upgraded before he bought the car?
  • did the canadian market one come with a smaller TB?
  • was chrysler just using whatever was on hand and didn't have any lawn mower TB's left while assembling FK5's car?
  • did the dream cruiser get the smaller TB so it was "dreamier" and easier to drive?
  #29 (permalink)
Old 12 Feb 2017, 11:49 am
Originally Posted by rob302 View Post
... chrysler just using whatever was on hand and didn't have any lawn mower TB's left while assembling FK5's car
no Chrysler would never do that!
  #30 (permalink)
Old 14 Apr 2017, 10:48 am
I was unaware of the 2 different tb's until I saw this thread. I recently got a plastic intake from a 06 gt auto and guy left tb on so I just used it. I cleaned it and replaced the tb to intake gasket but I didn't switch over the tps from my stock tb.. it seems to be fine but earlier in this thread someone said to switch over the sensors? What's that about? All there is are the tps and idle control right?
03 gt 5 speed Stage 1
Whoever says "There's no replacement for displacement " obviously underestimates RPM
AT Throttle Body in 5 Speed mvandale Turbo Performance 3 05 Dec 2006 12:03 am
POWERAID Throttle Body Spacer - Works?? matt87951 Tech & Performance Forum 17 23 Aug 2006 09:35 pm
Airaid Airmax and throttle body spacers Robster Tech & Performance Forum 22 22 Jul 2004 08:12 pm
Throttle body spacer for turbo? gt_tuner Turbo Performance 1 14 Jul 2004 10:02 am
Throttle Body Spacer PT-ERA Tech & Performance Forum 19 06 Jan 2004 03:06 pm
