Won't start first time
Old 13 May 2003, 10:34 pm
Default Won't start first time
We have discovered that the GT will not start first time hitting the key. Spin it a couple of time, no fire. Hit the key a second time and it cranks right up. What's the issue? Any ideas? Throttle position sensor? Fuel boiled out of the injectors? What?
Mike
Old 14 May 2003, 02:34 pm
Soounds like it could be a fuel pressure problem. On a lot of FI cars it takes a second for the system to pressurize before it will start. Try just turning the key on for a couple of seconds before you hit the starter and see if it goes the first time then. If so this is your problem. I do not have this problem on my PT but I used to experience it on my Mustang. The fuel system would bleed down after the car sat for a while. I believe that the fuel system in the PT is a "no return" type so I am not sure what the fix would. The Mustang would usually respond to a new pressure regulator but sometime they would need a new pump. The pump probably has a check valve that is supposed to maintain pressure on that side.
That is all I can think of right now.
My 2001 PT won't start! envision_man Tech & Performance Forum 4 29 Jun 2004 08:30 am
Long time no see... Ed Lim Non-PT Discussions 3 13 Jun 2004 11:20 am
Recommended warm-up time dbraveman General PT Cruiser Discussions 9 12 Feb 2004 09:38 am
Engine Warning Light 3rd Time - 04 GT RD CHILI General Turbo Discussions 18 12 Jan 2004 02:07 pm
Okay, Its about done....MG time. cruisergeo Non-PT Discussions 1 05 Sep 2003 11:32 am
