back fire some
Old 16 Jan 2006, 06:22 pm
Default back fire some
it was cold and i started the pt turbo about 5 or 4 minutes later i rev it and it back fire and stalled some,does the acceleretion has a cut off at certain rpm.thank for all your feed back[:I]
Old 16 Jan 2006, 06:38 pm
In cold weather, if you own a PT turbo or Supercharged one, like I do, you may want to let the engine warm up to normal operating temperature before reving it. You said you waited 4-5 min. That should be enough time. But if it was freezing temp. outside you may want to let it reach normal engine temp before driving it. That's what I do. Although, here in Tx. it doesn't get that cold. And my PT is always in a garage. If this keeps hapening, you may just need a tune-up or some new spark plugs.
Old 16 Jan 2006, 06:45 pm
does it happen only when cold ??
Old 16 Jan 2006, 07:44 pm
2step's Avatar
Yes there is a cut if you rev too high in park or neutral.
Old 17 Jan 2006, 08:56 am
You don't say how many miles on the PT....
Plugs & wires cure lotsa ills...
Suggest Crane wires (RaceAndStreet.Com) and new plugs.
Since you have a turbo, it's easy (unless you have plastic intake)..
Old 17 Jan 2006, 09:37 am
Send a message via AIM to dfunkdj
There is a rev limiter on your pt when its in park I'm not sure about netural.
I thinks its about 2500 rpm on stage 0 and maybe 3500 on stage 1 not sure.
Don
<font color=\"orange\"><b>2003 Dream Cruiser II
Stage 1, Greddy blow off valve, AGP WGA, Custom open dual exhaust, Denso plugs, Xtremeboost upcharge pipe, AMX intake pipe, Ramair hoods hood, Apc ground effects kit, lowerd 3\", Turbo xs MBC, auto meter double gauge pod, and 2 more gauge mountd on sterring wheel {oil psi and temp, boost, water temp}
apc 2nd gen tail lights, more to come soon
Tampabay Pt Cruisers</b></font id=\"orange\">
Old 17 Jan 2006, 10:34 am
thanks to all of you,great way to put someones nerves to rest.it only has 4000mls ,yes it was real cold! and yes in the next service call i will put new plugs and wires,you guys put out a lot of good info when it comes to turbo performance,wow alot of brown nose here huh,seriously thanks to all....
french`s
Old 17 Jan 2006, 10:36 am
on my part (about the brown nose)no no bad intended.thank u again
french`s
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
better put your back seats back Ctown General PT Cruiser Discussions 0 26 Feb 2006 11:21 pm
Holy "FIRE" Batman CREWZIN General PT Cruiser Discussions 2 11 Jun 2005 09:27 pm
Back power window switches not working lumofny Tech & Performance Forum 3 16 Jan 2005 10:00 pm
Looking for feedback on 3 inch turbo back system.. scottmech Turbo Performance 22 29 Feb 2004 11:30 pm
