PT Cruiser Forum Car Videos
Car Rims
high rpm miss
  #21 (permalink)
Old 04 Jan 2007, 10:16 am
Sturdevant Sturdevant is offline
So, the lights flicker at high RPM's, or at other times?
  #22 (permalink)
Old 04 Jan 2007, 11:12 pm
bobs turbo pt bobs turbo pt is offline
are the lights flicking under a load or all the time ??
  #23 (permalink)
Old 14 Mar 2007, 12:52 am
ValAir ValAir is offline
I have this problem with the high rpm miss also, even with the stage 1 it still does it. It's basically like a dead spot.
Also does anyone have a rough idle on their cars? or a drop in idle rpm and then it goes back to normal?
\'03 GT Black, 5 speed, Chrysler/Borla dual exhaust, Chysler performance air filter, Stage 1 kit, Plastic Intake, Chrysler B.O.V.,
Magnecore wires.
  #24 (permalink)
Old 14 Mar 2007, 07:56 am
quote:Originally posted by cookieman18
now i am having problem with the lights flickering so finally i got them to change the PCM i got the problem with the high RPM figured out but the light thing is another issue for me now.
Try addding more ground straps. Go to AdvanceAuto, etc, they have pre-made "battery cables" of differeing lengths. Go from - of battery to engine block, housing of computer, and body. It can't hurt.
  #25 (permalink)
Old 17 Mar 2007, 06:54 pm
littleblueGT littleblueGT is offline
I had the high rpm miss, the Dealer changed the PCM which corrected most of it. I found that the iridium NGK plugs really helped, but gapped at .047. Others have had good results at .030, but I found that the GT liked the .047.Any more than that there was spark blow out, any less the performance dropped off. The GT seems to have a "sweet spot".
vB code is On
high rpm miss gone tthrift Turbo Performance 8 06 Oct 2003 07:39 pm
...high RPM miss??? earringboy Turbo Performance 38 18 Aug 2003 09:32 pm
High RPM Miss Mean Green Turbo Performance 4 27 Jul 2003 10:46 pm
High RPM miss Lee01 Turbo Performance 23 30 Jun 2003 08:25 pm
High RPM Miss potential Fix Exhaust Depot Turbo Performance 11 15 May 2003 06:31 pm
  Savings Accounts | Remortgage | Mobile Phone | Hotels in Krakow | Debt Help
