question about plastic intake manifold
Old 12 Feb 2006, 05:34 pm
Default question about plastic intake manifold
is it good how mutch hp and what is the price because im very interested just need detail about that because everibody talk about that
Old 12 Feb 2006, 11:14 pm
I beleive about 8 hp & $65. from Haynes Speed Shop. You may have to remount you dipstick.
02 Silver Classic 5 speed with lots of chrome.
03 Cranberry GT A/S debadged.
Make a fast friend, adopt a greyhound.
Old 12 Feb 2006, 11:39 pm
About 8-10hp, add another $30 for a vanity cover, but don't use the foam backing that comes with it. You have to rework your stock dipstick bracket (not hard) or buy the updated dipstick (very cheap). Very worthwhile mod! Not just lighter, but less of a heatsink, and has a diverter to balance the airflow to all the cylinders.
Harry
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree......
Old 18 Feb 2006, 03:53 pm
and unless you go to a drag strip and get the official time...you are not going to feel 5 to 8 hp....plus your plugs become harder to change..
Old 22 Feb 2006, 04:09 pm
It depends on how much your GT is modded. I noticed a big difference when I started cranking up the BC after installing the plastic manifold. At higher boost, 18+, the metal intake manifold just doesn't flow like the plastic. And to get to the plugs, it just takes a universal joint on your plug socket!
The only advantage I see with the metal intake is that you could have it honed out to larger holes than the plastic, but it is a lot more than $65 for that and unless you're running a BIG turbo, I can't see spending a few hundred bucks for extrude honing and polishing
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 22 Feb 2006, 04:17 pm
I would also disagree. I installed the plastic manifold when I was still S0 and immediately felt a difference. I feel this is one of those mods that ends up being greater than the sum of it's parts. On a stock GT, it may just be a blip on the butt dyno, but as your mods increase it serves as a foundation for more power and provides exponential gains...And as stated, a properly sized universal socket precludes the need for manifold removal to get to the plugs....
Old 23 Feb 2006, 02:45 pm
[8]Its called mind games...If you believe it enough you will be convinced...
Old 23 Feb 2006, 08:41 pm
Call me crazy but I find this debate really amusing. The LT-1 community sees this completely different. As the former owner of an LT-1 Camaro which came with a composite "plastic" intake manifold. One of the first mods to be done was to dump the intake in lieu of a metal manifold that created more power (dynoed 8-10hp). This was especially important if boost was going to added.
As I have not experienced a PT with the change I cannot comment on the difference it makes but in the Camaro getting rid of it did.
Just my 2c
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright brothers. But they also laughed at Bozo the Clown.
Carl Sagan (1934 - 1996)
Old 23 Feb 2006, 11:18 pm
QUOTE:
"Call me crazy but I find this debate really amusing. The LT-1 community sees this completely different. As the former owner of an LT-1 Camaro which came with a composite "plastic" intake manifold. One of the first mods to be done was to dump the intake in lieu of a metal manifold that created more power (dynoed 8-10hp). This was especially important if boost was going to added.
Just my 2c"
You must be very easilly amused. A PT intake has nothing to do with a Chevy intake. Whichever intake has better flow is the one that will perform best. I'm sure you're right about those Chevy intakes.
The GT plastic intake was re-engineered to do it's job better than the old one. It is a fact that the Cruiser Turbo, plastic intake flows better, balances the cylinder filling better, has smoother insides, makes more power and is lighter to boot.
Old 24 Feb 2006, 02:07 am
Actually, LT-1s didn't have plastic intake manifolds. That's the LS-1. I have owned 2 of them, and a 1994 Impala SS, and none of them had composite manifolds.
PLASTIC GT MANIFOLD PROBLEMS? littleblueGT Turbo Performance 45 25 Nov 2011 12:10 pm
Plastic PT Cruiser Intake Manifold Kit hangtym3 General Turbo Discussions 59 11 Aug 2005 09:10 pm
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
