PO121 fault code
Old 13 Feb 2006, 10:30 pm
Default PO121 fault code
a couple weeks after installing my AGP wastegate actuator, while driving on the highway sometimes the check engine light comes on and the code PO121 comes up.Throttle position sensor and MAP sensor disagree with each other. Once this happens the car idles at like 3000 rpm's and does not want to idle down when slowing down. After turing the car off and restarting it, it would be perfectly fine. If anybody has any input on what could be causing this, it would be greatly appreciated. I already relpaced the map sensor and the tps and it did nothing.
Old 14 Feb 2006, 12:02 am
is there an idle sensor ?? i had a car 86 duster at least i think it was an 86 ?? well anyway, the idle sensor went three times on that car, but it did the same thing your car is doing let us know what you find out good luck !!
Old 14 Feb 2006, 11:16 am
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
Strange that it clears with a restart....[:I]
Old 14 Feb 2006, 12:14 pm
P0121 is throttle position sensor #1 performance . Could be the sensor, power, or pcm. Leave the code and get car to dealer to diagnose ..... there are 3 pages of diags and you need DRBIII to perform most of them.
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree......
P0440 fault resets and comes backin PT cruiser2003 sonny General Turbo Discussions 4 08 Nov 2011 07:49 pm
Mopar radio security code. Ian-PT-GT Sound and Security Forum 11 24 Feb 2010 02:19 pm
Need diag. code info RIvey Tech & Performance Forum 1 01 Oct 2005 12:05 pm
Fault code RossiePT General Turbo Discussions 8 28 Mar 2004 10:52 pm
P 2302 Fault Code unable to find Turbo Red General PT Cruiser Discussions 2 08 Feb 2004 12:37 am
