Mopar Blow-off valve kit.
Old 19 Feb 2006, 11:35 pm
Default Mopar Blow-off valve kit.
[8)]Anyone have the Mopar Blow Off Valve Conversion Kit on their PT Turbo? Like it? Hate it? Better sound? Any opinion?[^]
Old 20 Feb 2006, 02:19 pm
We have it and we like it just fine.
The BOV (and MP STage 1 kit) came on the car when when purchased, so it did take a little getting used to the 'pffft ', but it turns out that it's not so loud that it becomes annoying.....at least to us.
If I'm trying for maximum economy, I play a game to try and drive without triggering the BOV. It can be done with some practice [^]
Brian
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
Old 20 Feb 2006, 07:13 pm
It is realy a sound machine and does little, if anything, for performance or longevity.
Old 21 Feb 2006, 02:25 am
I like mine. It is fun driving around and when my buddy joins me with his Stage 2 SRT-4 hearing both cars go "pfffffft!" almost in unison and seeing pedestrians turn their heads.
2004 TE Turbo Auto (Silver)
Mopar Stage 1 w/ Mopar BOV, Mopar CAI, 2.5\" Dual Outlet Heartthrob Cat Back Exhaust System, Gold Line lowering springs 1.50\" front and 2.00\" rear and APC Gen II Euro Tail Lights.
Old 21 Feb 2006, 11:42 am
I have it. Like others have said, it's really just a noise maker, does nothing for performance. But, it doesn't lessen the performance of the stock system either. The sound takes some getting used to, but I like it on mine.
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree......
Old 21 Feb 2006, 02:56 pm
Anybody have one on an auto? I used to have a GMC Typhoon and it was not recomended since you never let off the gas under hard acceleration. Unlike a manual where you have to let off to change gears.
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright brothers. But they also laughed at Bozo the Clown.
Carl Sagan (1934 - 1996)
Old 21 Feb 2006, 03:43 pm
mines an auto
Old 21 Feb 2006, 10:51 pm
quote:Originally posted by Black_GT
mines an auto
Does it release pressure with every shift or just when you let off the pedal?
Old 22 Feb 2006, 04:14 pm
It will blow with every shift of the auto with one exception, if you have stage 1 installed and you go WOT, then the PCM holds the boost through the shift so you have more power going into the next gear. It also has this feature on the manual trans stage 1, but you have got to be real quick on the shift or you'll hit the rev limiter and that will cause a drop in pressure due to the fuel being cut.
edit to add:
The mopar kit is fine(1st BOV I had), but I like the Forgemotorsports.com one for the srt-4. It looks better(all chrome exterior), it's easier to install(installs in two seperate pieces making it easier to bolt up to the turbo), and is adjustable(spring package option that's really easy to change) if you add boost through the modding process. I also think it sounds better.(has more vent holes)
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 22 Feb 2006, 04:25 pm
On my auto it wouldn't blow between shifts, as long as you didn't lift the throttle. Now when it was Stage 0, it would blow every time you lifted the accelerator, even when not under boost. With Stage 1 it seems to work a bit better.
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
EXPLODED VIEW OF OEM BLOW OF VALVE littleblueGT Turbo Performance 2 24 May 2006 09:15 pm
Stock blow off valve DMW General Turbo Discussions 8 12 May 2005 06:08 pm
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
