PT Cruiser Forum Car Videos
Custom Wheels
Low Voltage?
Old 20 May 2003, 10:36 am
GTPT GTPT is offline
Default Low Voltage?
Just installed gauges. I tapped lights into wires for preexisting light wires and do not have light. Does anyone know if the current for the PT's lighting is lower than bulbs supplied with AutoMeter gauges? Thanks, Phil
Old 20 May 2003, 04:05 pm
higear4 higear4 is offline
Maybe you didnt hit a 12V source. The wire that is used for the headlight/guage lighting is a pink wire. You can find it by opening the fuse panel to the left of the steering wheel. Then unscrew the fuses blocking two groupings of wires. There should be a group of eight wires right behind the fuses (a little above) The pink wire should be the top right wire of the group. This is the wire i used and have had no problems with my autometer guages.
Set the geere shift for the high gear of your soul!!!
http://interactive.colum.edu/students/jsoltes/IMP/projects/project%201/ptperform.html
Old 20 May 2003, 04:16 pm
Thanks for the info. Phil
Old 20 May 2003, 04:53 pm
RobGT RobGT is offline
The orange wire running right up the A pillar is connected to dimmable dash lighting.
I used this one and it also works great. Gauges dim with the dash. Tapped in with a solderless connector.
My $.02
Click to see my GT!
Old 21 May 2003, 10:22 am
dgc333 dgc333 is offline
Do not forget that you need a ground.
If the gauges came with a seperate ground wire make sure what ever you connected it too is truely grounded. I have seen metal stiffeners under dashes that are isolated from the chassis and hence are not grounded. Also, if the gauges do not have a seperate ground wire with the expectations that they are being grounded through the housing, you will not have a ground if they are in a plastic guage pod. You will need to add a ground wire.
Dave Clement
\'03 GT, Electric Blue
Old 21 May 2003, 01:48 pm
Thanks guys, I finally found the problem. The connector wasn't making full contact with the lighting wire. I'm good to go!
Phil
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Volt meter OurPTGT General PT Cruiser Discussions 7 28 Jul 2003 09:09 am
  CreditCards | Car Loan | Cheap Loan | Mortgage | Mobile Phone
