Power loss
Old 10 Apr 2006, 09:16 pm
Default Power loss
I heve a power loss that feels like I am loosing boost. I have checked all lines and intercooler hoses, but everything looks good. There are no CELs. Does anyone know if the stock blowoff valve or pressure relief valve can hang open? I haven't seen any drawings so I'm not sure.I would appreciate the help, thanks.
Old 10 Apr 2006, 11:37 pm
Did you do a boost leak check (pressure test)? You really can't tell with the engine running if there is a leak or not. You do the test with the engine off and you can hear anything leaking.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 11 Apr 2006, 09:33 pm
Thanks Mean Green, but after posting I went back out to the car and found my leak! I put the car on rhino ramps, had the wife rev to 3,000 RPM while I felt around the IC hoses. Later I took a pen light to view the lines under the air box hose, and thats where it was. A line under the hose coming from the turbo had blown off. Before I had tie wrapped the other lines in the area, but this one appeared to have the connector molded in so I didn't. Now all the lines are tie wrapped that I can't put a regular hose clamp on. By the way the flow back catch can/brass check valve combination is still working very well. Take care.
Old 11 Apr 2006, 11:45 pm
Right on!
Power Seat? Musicman General PT Cruiser Discussions 7 20 Feb 2006 09:49 pm
Power Loss LoboMXGT Turbo Performance 2 15 Aug 2005 04:00 pm
How to get power to my mp3 player & other concerns Doktor X Sound and Security Forum 3 29 Jul 2005 10:38 pm
Power loss? turbomangt General Turbo Discussions 9 28 Jul 2005 12:55 am
Power loss Betsey General Turbo Discussions 5 10 Dec 2003 03:45 am
