Jet Performance
Old 06 Jul 2006, 04:34 pm
Default Jet Performance
I installed a Jet Performance Chip (Stage 1) for my '04 Turbo.
I installed exactly as the instructions described but my check engine light came on and the performance decreased. I took it back off but the light remained on and now the A/C doesn't work.
Any suggestions?
Old 07 Jul 2006, 01:28 am
First off, you should have asked around here and other PT sites about the Jet Chip first.....we would have steered you away from it as a total and complete waste of money. Mopar Stage 1 is the only way to go.
Sorry, had to get that out.
OK, now to address your problem. Do you know what code you've got now? Turn the key on/off/on/off/on/off/on and see what code(s) appears in the odometer display and post them back here. After doing that go ahead and disconnect the battery for several minutes to reset the PCM. This should clear the code and check engine light, and with any luck your A/C will be back up too. No guarantees about the A/C though.
Old 08 Jul 2006, 02:15 am
I would also have to vote for stage 1 rather than that Jet chip. Most chip companies wont give you back your money so you can get real stuck! Our engines are very prone to throwing off error messages if you modify the engine without stage 1!!
Old 08 Jul 2006, 03:50 am
Stage 1 is the only way to go. It's the building block to more power.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Hybrid Performance strangelove General PT Cruiser Discussions 1 04 Apr 2006 11:14 am
PT- 2.4 L Turbo: Performance Kit IS SOLD! JeffreyPT2003 Canada PT Forum 1 08 Mar 2005 07:44 pm
The JET PERFORMANCE CHIP is amazing... Gary04GT Tech & Performance Forum 9 13 May 2004 12:00 am
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
Mopar Performance Parts Warranty Dalite Turbo Performance 0 07 Jun 2003 10:44 pm
