PT Cruiser Forum Car Videos
Car Rims
Check engine light, ever hear of these codes?
Old 08 Jul 2006, 09:19 am
MINIHEMI46 MINIHEMI46 is offline
Default Check engine light, ever hear of these codes?
Hello out there, I'm asking for help with my 03 all stock (no stage one) GT 5 speed before I take it to the dealer. The other day a friend used my GT to go to NASA to see the Space Stuttle lift off and now these computer codes are coming up and it's making weird noises now. He says it didn't hit, bump or race anything but I find it hard to believe him. I've read some websites about these codes and they all say the codes start out with P then the # but these codes don't say that or I'm not reading it right. The first code that comes up is FL0007 Second code is EE 10 Third code is BL 01 The GT runs great, maybe a little better than before because I'm getting third gear tire spins at WOT. Now this weird noise that I'm hearing sounds just like big 4x4 tires that whine driving down the road, it's never done this before and it's getting louder. I reset the computer by unhooking the battrey but then after a little while the light comes back on with the same codes. I've looked at all the tires about the noise and see nothing wrong. I've taken it out of gear and coasted at all speeds, same noise. Taken it on twisty roads, same noise and it doesn't make any different sound (the whine pitch). The noise starts at around 10 mph. Don't think it's the transmission because it shifts fine. The clutch works just like it did and it drives just like it always did just with the whining noise now. I thought it may be a rear tire bearing but I've never heard of one tripping the engine light. I don't think I've left anything out and I hope someone can help me out. Thanks
Old 08 Jul 2006, 09:54 am
CREWZIN CREWZIN is offline
I'll try and help. I don't think your reading the correct fault codes. To obtain the fault codes your looking for, put the key into the ignition and turn it towards the window (forward) three (3) times without actually starting the engine. On the 3rd turn forward, leave the key facing the window and the codes will then show up in the center dial.
The "codes" that you were seeing is the PCM information codes that you see when you do a "Dial Test". That's holding the reset button IN while turning on the ingnition key. All the dials will go through a test and then give you some information codes.
Old 08 Jul 2006, 11:09 am
bobs turbo pt bobs turbo pt is offline
wheel noise, heres a thought, look on the backside of the rims see if any are dented it happened on my wifes pt rim had a split and a big bubble , you couldnt see a thing by looking at it from the outside , good luck & keep us posted
Old 08 Jul 2006, 02:05 pm
I did it that way with the key, turning it on while pushing on the trip miles button. It tells the serial # of the car, then the codes, then it cycles through the gauges. So I think I'm doing it right
Old 08 Jul 2006, 05:48 pm
NO. You did exactly what I told you to do to get the INFORMATION CODES, not the FAULT CODES. Leave your finger OFF the reset button and turn the key 3 times to the ON position leaving it to the ON with the last turn. [xx(]
Old 10 Jul 2006, 10:38 am
For the noise, I'll bet on a wheel bearing.
Read and compare:
http://ptenthusiasts.org/forum/showt...d=1#post586896
for the codes - just use the key (not trip odometer) or go to AdvanceAuto, AutoZone, etc, and they'll pull the codes for free.
Old 10 Jul 2006, 07:41 pm
Ok, I finallyread the codes right and code is 0551 which is the power steering switch. Now where is this switch so I can replace it?
Thanks
vB code is On
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Check engine light on - & NO CODES?!?! CraigO Turbo Performance 9 20 Dec 2003 02:42 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 11 10 Jul 2003 04:55 pm
  Kangen Water | Credit Cards | Remortgages | Mortgage Calculator | Loans
