"Performance Brakes"
Old 26 May 2003, 04:39 am
Send a message via AIM to BC4BigMac
Default "Performance Brakes"
What is so "performance" about the upgraded brakes included on the 2003 PT Cruiser Turbo? To be honest, the brakes on my 03 Turbo don't feel any better than those on my dad's 01 Limited PT.
-Adam (18/M/CA)
Old 26 May 2003, 06:11 pm
the discs are bigger, as well as the callipers. The bigger disc adds surface area for the callipers to grip, resulting in better stopping distances. But you are right, they should have cross drilled them and put some serious callipers on. However, there is still a noteable difference[^]
My Cruiser is slow. I love the law.
Old 27 May 2003, 04:44 am
Well, Mr. Mac, I believe that Chrysler used marekting strategy in saying "performance brakes" are included on the GT Crusier. The rotors and calipers are enlarged a lil but not enough to call them performance brakes.
I suggest you get aftermarket true performance brakes. 12 or 13 in rotors and four piston calipers would be ideal. But these calipers will cost you around 1200$ including the rotors. The rotors should also be slotted and not crossdrilled, as crossdrilled rotors tend to crack around the holes over time and the structural integrity degrades. If you look at any race car, you will see slotted rotors now. If the rotors do have holes...they are molded in and not drilled.
Also, the rubber brake hydraulic lines should be replaced by stainless steel lines to get rid of the pulsating effect of the rubber lines induced by hard braking. Braking will be more fluidic this way.
Peace out mac!
Kack
Give me a turbo and I will sing you a song!
Old 27 May 2003, 01:13 pm
Braking is a function of both the caliper/disc and the TIRES. The reason that you don't feel much difference on the GT brakes is the TIRE that DC put on the GT.
The old adage that you cannot be all things to all people is very true of tires. The stock tire will go in rain, snow, mud and fairly well on dry pavement. Check Tire racks ascessment. This is a fairly vanilla not so performance tire.(They put Potenzas at twice the cost on the SRT4.)
When it comes time for a tire renewal; get some performance 215/50 size tires.....then you will see a difference. Also the discs are fairly soft and usually need replacement on the first brake job... a good time to replace with cross-drilled ones from aftermarket and maybe Hawk or performance pads as well..
Old 27 May 2003, 06:16 pm
Personally I don't think the brakes (calipers and rotors) need to be upgraded unless you are going to be competing in roadracing events. When I get on my brakes they haul it down right now. When it is time to do brakes in the natural course of events, I will put on some slotted rotors and good pads and do the brake lines but as for swapping out the whole system I don't think it needs it.
Old 27 May 2003, 06:49 pm
so true, unless you actually plan on doing road/circuit racing in thie car ( which is kinda rediculous to begin with ) a $1200 dollar aftermarket system could be $$$ used better else where IMHO. For $1200 you could do full suspesion (sways,springs etc), and a bitchin' electronic boost controller and still have $$$ to play with! [?]
Old 28 May 2003, 03:55 am
Ture true. But I was suggesting the brake system overhaul not because it is needed, but because if Mac wants performance braking, this is what he will want to get. That is if he has the $$$ to spend. Personally, Suspension should be first, then the brakes, then the engine. You have to have the stopping power to stop all that 'go' power the GT spits out of its 2.4 Litters. You also should have the means to put down that power and not sway the car all over the turns...hence the suspension upgrade.
Just my two penies!
Kack[8)]
Old 28 May 2003, 07:11 pm
for aftermarket brakes, Wilwood, Bear, or Stop-Tech make good systems...[^]
Hybrid Performance strangelove General PT Cruiser Discussions 1 04 Apr 2006 11:14 am
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
High Performance brakes for PT GT Kirby Turbo Wheels/Suspension/Handling 64 07 Jun 2004 10:50 am
The JET PERFORMANCE CHIP is amazing... Gary04GT Tech & Performance Forum 9 13 May 2004 12:00 am
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
