Removed my champions and regapped @ .040 And all is running fine wound out to 125mph this afternoon on an open stretch of deserted highway. Speed was still climbing when I got off of the throttle. The EGT went up to about 1400 and hovered between 1350 & 1400 at wot and that speed (Stage II Boost@13.5 lbs). I think now that I am convinced that the problem is solved (been a number of days with the plugs@ this configuration)
Gearhead you had a post over the weekend with the NGK numbers for normal and the colder plug. What happened to it? Could you please post those #'s again? Thanks!
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp |
NGK plugs:
Stock - BKR6E 1 range Colder - BKR7E
2003 Electric Blue PT Cruiser GT 5-spd MOPAR Stage 1 kit Custom Stage 1 emblem on rear hatch Greddy Turbo Timer AGP factory surge valve blockoff plate AGP/TurboXS Type H-RFL BOV 160 degree thermostat Magnacore plug wires Champion RE14PLP5 Double Platinum plugs gapped .050\" Screamin Demon coil Momo shift knob 3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges Stewart Warner Shift Light Streamline Designs third brake light overlay \"Turbo Cruzer\" Rear splash guards Rear spoiler Hidden Hitch Ichiban pedals Streetglow Xenon headlight and foglight bulbs PCV line oil seperator Firestone Firehawk SZ50 215/50R17 tires PT Tuning axle back exhaust and muffler Mr. Dyno vehicle performance computer Pioneer DEH-P77DH AM/FM/CD Kenwood KSC-WA62RC The WooX 30w x 2 powered subwoofer
Thank you, gsharrock!
*UPDATE* Recieved the NGKs today, and the reach on these plugs do not match the champions from the cruiser. I will be calling NGK today to see what the deal is and try to straighten this out. Sorry for the mis-information, I'll post as soon as I clear this up !!! [:I]
Alan |
Gear Head,
What NGK part # did you get?!
The NGK Stock# was 6962 and the plug designation was BKR6E. This plug does not have the thread reach into the head to match the champion plugs currently installed. I am working with extreme motorsports in jessup MD as well as a few other sources to try to clear this up. The reach on the Champions is almost 2X as long as the NGKs listed above. As soon as I get the right info, I'll post it, but I am going to wait and physically verify the plug size, etc.
BEFORE POSTING (I should've done that the 1st time) [xx(] Alan |
Good luck...I bought the "wrong" ones ,too from Advance Auto this morning . Went back gave them the 5306 number ,they called NGK got a real # LTZ4-11 but are unable to order for me. I pulled the champions and re-gapped down to .040 .
Let's try this:
Stock Champion **** plug is RE14MCC5 (stock #440). The Double Platinum replacement is RE14PLP5 (stock #7440). I have those in my car now. Both Champions are a 14mm thread, 1" reach, taper seat, 5/8" hex. Neither of those Champion numbers can be cross-referenced to an NGK number. However, both cross reference to Denso Iridium number ITV16. The ITV16 14mm thread, 25mm reach, 16mm(5/8") hex, tapered seat, 0.4mm iridium electrode, tapered cut U-groove ground, resistor, 0.44" gap. If you want to go to a colder Denso plug, the number is ITV20. The Denso's are about $11.99 each.
gsharrock how's the double platinums running in turbo ? I know that MX5 who designed the plug had stated that it wouldn't be a good choice for turbos/sc cars to run. That's why I didn't even try the doubles in my turbo although I'd had good luck running them in my na cruiser.
| high rpm miss | 1quickpt | Turbo Performance | 24 | 17 Mar 2007 06:54 pm |
| high rpm miss gone | tthrift | Turbo Performance | 8 | 06 Oct 2003 07:39 pm |
| ...high RPM miss??? | earringboy | Turbo Performance | 38 | 18 Aug 2003 09:32 pm |
| High RPM Miss | Mean Green | Turbo Performance | 4 | 27 Jul 2003 10:46 pm |
| High RPM Miss potential Fix | Exhaust Depot | Turbo Performance | 11 | 15 May 2003 06:31 pm |
