PT Cruiser Forum Car Videos
Car Rims
High RPM miss
  #21 (permalink)
Old 03 Jun 2003, 08:30 pm
gsharrock gsharrock is offline
The double platinums have been in for a week and a half gapped at .045". The engine seems smoother and pulls better close to the red line. I'd say they're better than the stock Champion "Industrial" plugs (that's what Champion calls them!). I'll wait before I try the Denso's. Gotta pay for Stage 1 kit now!
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC — The WooX 30w x 2 powered subwoofer
  #22 (permalink)
Old 03 Jun 2003, 08:46 pm
Dalite Dalite is offline
Maybe MX5 will weigh back in on the subject. He and Bob Stockum had found that detonation was a problem with turbo and supercharger add-ons and performance enhancements on the 2001 and 2002 models. For that reason, I think it was decided that the #440 was the best choice for higher heat applications.
It was discussed previously that the double platinums would possibly give more area to heat up and cause premature detonation (like dieseling) in high heat apps.
I haven't taken part in any experimentation, other than relaying what I have read in other forums. My GT is now doing a little bucking between 4500 and 5000 RPM under boost; most noticable om the 2nd to 3rd gear shift. It is a 5 speed, and I don't have any place close by to try it at that RPM level on 3rd to 4th shift or higher. I suspect the results would be similar.
I think there was discussion also about using a colder plug, or possibly a shorter reach one.
One aspect that bears some consideration is what happens to the plug wires if the plugs start missing. The wide gap calls for a hotter spark, and the coil assembly(s) are probably capable of delivering higher voltage levels under misfire than the plug wires can consistently handle without breakdown. At some point, plug wire breakdown would have to be factored in, and if overlooked, could add considerable confusion to diagnosing the overall problem.
  #23 (permalink)
Old 29 Jun 2003, 11:58 pm
OVcruzn OVcruzn is offline
Just bumping the topic to see if anyone installing the Stage 1 kit has noticed an improvement in the high RPM miss some of us are getting around 5K.
Dreamin\'.....
2003 Dream Cruiser 2 #1765 (May 2003)
Silencers out, K&N in, Chrome fuel door.
[IMG]ftp://gopropakassword@members.cox.net/gopropak/emblem.jpg [/IMG]
  #24 (permalink)
Old 30 Jun 2003, 08:25 pm
Exhaust Depot Exhaust Depot is offline
Send a message via AIM to Exhaust Depot
once you lower your gap, you should stop missing. I think i posted on this over a month ago and some of you guys got good results. I would not go more than 1 heat range colder. Also if your not boosting yoru car to 15psi etc, then I would leave the same heat range but will lower the gap.
Happy boostin!
Hec
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
vB code is On
high rpm miss 1quickpt Turbo Performance 24 17 Mar 2007 06:54 pm
high rpm miss gone tthrift Turbo Performance 8 06 Oct 2003 07:39 pm
...high RPM miss??? earringboy Turbo Performance 38 18 Aug 2003 09:32 pm
High RPM Miss Mean Green Turbo Performance 4 27 Jul 2003 10:46 pm
High RPM Miss potential Fix Exhaust Depot Turbo Performance 11 15 May 2003 06:31 pm
  Loans | Web Advertising | Personal Loan | Bad Credit Mortgages | Mobile Phones
