PT Cruiser Forum Car Videos
Custom Wheels
AGP Wastegate
Old 15 Oct 2006, 03:08 am
strangelove strangelove is offline
Default AGP Wastegate
Search feature doesn't seem to work to well on this site anymore so I thought I'd start a new thread. I ordered the AGP Wastegate Actuator for my 03' PTGT. Do I need a boost controler or can I istall the wastegate on it's own?
Old 15 Oct 2006, 03:53 am
Mean Green Mean Green is online now
You are going to need a boost gauge before you install the wga. You need to know what you are boosting to be safe. You can install wga on it's own. Set it at 13 psi. Without a bc you will have PTB, actually bad PTB. I installed a dual stage bc on my '03 GT along with the AGP wga. I had the 1st stage of the bc set at 15 psi. No PTB in any gear. The 2nd stage of the bc was set at 18 psi. Bad PTB in the first couple of gears (5 speed). No PTB from 3rd gear on. The trick was to use the 1st stage of the bc for 1st and 2nd gears so there was no PTB. When I hit 3rd gear I flipped the switch to the 2nd stage of the bc. Then it was hang on to your hat, Martha. My wife (not named Martha) called the bc switch the "evil switch" and I had to tell her before I used it so I didn't snap her neck off. [|)]
I could drive in 1st and 2nd gears on the 2nd stage of the bc, but I had to go easy in 1st and 2nd gears to avoid PTB until I hit 3rd gear. Then it was punch it and go. The GT was a blast to drive. [?]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 15 Oct 2006, 10:26 pm
What type of BC did you use?
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 15 Oct 2006, 10:57 pm
I used a Turbo XS dual stage bc. It's manual and cheaper than an electric one.
Old 15 Oct 2006, 11:41 pm
Is this the BC you installed?
That must be the red "evil switch" lol!!! [^]
Old 16 Oct 2006, 02:12 pm
Yep [?]
Old 17 Oct 2006, 08:09 am
I like the thought of having dual stage boost control with a switch to go from one to the other. Makes sense to be able to trip a higer boost during 3rd gear, there would probably be to much wheel spin in 1st and 2nd gears if you were running 18 psi boost. Where did you put you boost guage?
I found another bc made by AEM which is a bc and a guage in one. Not sure if it has dual settings, but I like that it's a guage as well.
Old 17 Oct 2006, 02:46 pm
Gauge pod.
The problem with a single stage bc is if it is set above 15 psi you will get bad PTB.
Old 21 Oct 2006, 08:01 am
Nice pillar pod, yeah I think a dual stage boost controler would be better. The search goes on.
vB code is On
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
AGP Wastegate actuator CJJ Turbo Performance 20 30 Nov 2004 09:46 am
Boost control W/ vs W/O wastegate 2step Tech & Performance Forum 3 17 Nov 2004 01:39 pm
Wastegate Info Needed GTPT Turbo Performance 10 05 Dec 2003 12:16 am
Wastegate Actuator And No Need for Boost Controlle FRM3 General Turbo Discussions 11 01 Dec 2003 10:51 pm
  Mortgage Loans | Loans | McDonalds | Remortgages | Download movies
