3.0-inch AGP Intake
Old 16 Oct 2006, 06:56 pm
Default 3.0-inch AGP Intake
Think I'm going to get the PT Cruiser AGP 3 Inch Intake. Is there any other intake with a 3 inch diameter intake? Most manufacturers don't say. Reason for this intake is I'm going to replace the stock turbo with something bigger and going with a 3 inch exhaust system.
link: http://www.agpturbo.com/product.php?...cat=309&page=1
Second choice might be the K&N Typhoon.
Third choice might be the Mopar intake.
What Have other people done?
Old 17 Oct 2006, 02:52 pm
With an open intake you'll suck hot air. On the dyno you'll gain 2-3 hp and lose double digit numbers of torque. If you are bound and determined to get an intake then get an Airade intake. At least they try to seal off the hot engine air. On my '03 GT I had a modified stock airbox and replaced the very restricting turbo to airbox hose.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Oct 2006, 08:30 pm
Yep heat is a problem under the hood. What size are the pipes from the Airraid Intake? Hey is that AMX guy still making intakes?
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 18 Oct 2006, 03:22 am
Yep, he is still making Hot Air Intakes. The Airade is the same diameter as stock because your stock hose from the turbo hooks up to it.
The Airade replaces the top of the stock airbox and seals up against the hood to keep hot air out.
Old 19 Oct 2006, 02:32 am
Put one of these on the end of the intake.
http://shop.knfilters.com/KNShop/Pro...sal+Air+Filter
2004 TE Turbo Auto (Silver)
Mopar Stage 1 w/ Mopar BOV, Mopar CAI, 2.5\" Dual Outlet Heartthrob Cat Back Exhaust System, Gold Line lowering springs 1.50\" front and 2.00\" rear and APC Gen II Euro Tail Lights.
Old 19 Oct 2006, 04:35 am
Now that's a good thing. I don't know if this is the same thing but it's called the K&N Apollo.
Not sucking any hot air there.
Old 21 Oct 2006, 07:46 am
I got a hold of Jim the AMX Intake guy and he says that he still makes a 3.0 inch intake that will fit both the stock air box and an Airaid Intake enclosure. Meangreen does your Airaid enclosure allow you to cut the weather strip along the enclosure to alow cold air in, or does it draw air in from the fender well?
Old 21 Oct 2006, 03:52 pm
I don't have the GT anymore but you can remove a portion of the weatherstripping on the side by the Airade and draw cold air.....Yes, Jim makes a very nice turbo to airbox hose that I recommend.
MOPAR Cold-Air Intake Review blueberrygt Turbo Performance 12 23 Sep 2005 01:04 pm
GT cruiser powder coated intake tthrift Classifieds: For Sale/Trade 1 04 Jul 2004 12:29 pm
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
pt tuning intake VS Ebay intake gt_tuner Turbo Performance 8 21 Jun 2003 11:41 pm
AIR INTAKE FROM AMX1397 amx1397 Turbo Performance 6 03 Jun 2003 10:22 pm
