AGP wastegate w/o boost control
  #11 (permalink)
Old 09 Mar 2007, 04:56 am
Think of stage 1 as the building block for all your mods. If you don't use stage 1 and you mod you will most likely have fits with error codes.
  #12 (permalink)
Old 09 Mar 2007, 10:04 pm
I'll be checking the other site for info on stage 2 WGA, I haven't installed the APG WGA yet so I might go with what bababooie is suggesting. For people on this site though, could you explain how you would tune S2 WGA with a S1 PCM. Is there an adjustable arm on the S2 WGA? And would it still be a good idea to do this mod with a boost guage or boost controler?
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
  #13 (permalink)
Old 10 Mar 2007, 05:30 am
they only way you'll be able to see if its working right is if you have a boost guage. If you're gonna mod these cars beyond stage 1, you need a boost guage. No way around it.
  #14 (permalink)
Old 13 Mar 2007, 01:22 pm
hharper1321's Avatar
GET A BOOST GAUGE!!!!!!!!! And yes, the S2 WGA has an adjustable arm. You won't need a boost controller, but can add one if desired....
2004 PTGT - Stage 1 and a bunch of bolt-ons, even more bolt-ons waiting in the garage!
How come "The People" in the First Amendment means The People; "the People" in the Fourth Amendment means The People; but "the People" in the Second Amendment (ratified in 1791) means the National Guard (created by an Act of Congress in 1903)?
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Boost control W/ vs W/O wastegate 2step Tech & Performance Forum 3 17 Nov 2004 01:39 pm
