Cold Crank, 2nd Try.
Old 09 Jun 2003, 06:44 am
Default Cold Crank, 2nd Try.
When I try to start my GT (when it's cold) it sometimes doesn't start on the first try.
It has 8,000 miles on it, and the dealer told me not to give it any gas when I start it, so I just turn the key.
I'm wondering how this compares with other GT's. Do you give it any gas before a cold crank? How quickly does it start if you don't?
Thanks.
Old 09 Jun 2003, 07:06 am
Send a message via AIM to PK Cruiser
(knock on wood) mine always starts right up, even in cold weather (which is long past here in Georgia). I never give her any gas, and haven't seen any problems yet...
\'03 Black Turbo, Autostick, Removed Intake Silencers, K&N Drop in Filter, MOPAR BOV, Eibach Springs, Kenwood CD/MP3 Player & amp, 12 inch Sub...soon to be a member of the Stage I club...
Old 09 Jun 2003, 07:25 am
You should never give any fi(fuel injected) car gas to start . Read your owners manual. Turn key on listen for fuel pump turn-on and crank motor . If you're giving it gas you're probbably causing the issue.
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 09 Jun 2003, 08:35 am
The only reason for using the accelerator was for carburated vehicles. It was primarily done to engage the choke plate.
Phil
Old 09 Jun 2003, 07:12 pm
Send a message via AIM to Exhaust Depot
My SRT has dont that a couple of times also. I could crank it till the battery dies and it would not sstart. On the second try it works.
SOunds like the PCM and some sensors are not up to par at times. It has nothing to do with you putting your foot on the gas.
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
Old 09 Jun 2003, 09:10 pm
like flashbk2, you should engage the fuel and oil pump by turning the key so that electronics come on line, then wait 3-5 seconds . Then turn on the engine. This will allow for better starts all the time...it's also better for the motor
My Cruiser is slow. I love the law.
Old 09 Jun 2003, 11:19 pm
Great advice, Thanks!
Before this '03 PT, the newest vehicle I'd owned was a 1972 Ford V8 Van. Before that was a 1970 V8 Mercury Cougar, and before that was a 1968 V8 Olds Cutlass.
The Fuel Injection and all is still new to me.
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
Old 10 Jun 2003, 03:59 am
Mine is sometimes hard to start the first time, too, though it does start. I'll give Cop Tzer's advice a try.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 Jun 2003, 09:59 am
FYI, few points on comments in this thread.
The fuel pump will only run for a second or two after turning on the key unless it sees a signal from the crank trigger that the engine is turning over (and this may be rpm dependent). This is a safety feature that prevents the fuel pump from pumping gas onto the ground if the car is involved in an accident that ruptures the fuel line. So turning the key on and waiting for anything more than a second does no good. However, if an injector is leaking down turn the key on an off a few times may cycle the pump enough to get the pressure (certainly a resonable explanation for starting on the second try).
The oil pump is mechanical and requires the engine to be turning over to generate pressure, so turning on the key does no good unless of course you purchased an aftermarket pre-oiler that maintains oil pressure when the engine is not running.
As others have stated there is no choke to set so the normal procedure for starting a FI engine is not to touch the gas. However, FI cars can be flooded just like a carburated car if an injector happens to stick. If the engine does not start after a second or so of cranking with a including more than one key cycle it could be flooded. Holding the throttle to the floor, just like you do for a carburated car will work if it's been flooded. My Avenger does this every once in awhile and holding the throttle to the floor works.
Dave Clement
\'03 GT, Electric Blue
Old 10 Jun 2003, 10:44 pm
Yep, That was why. Turning the key, then waiting a second or two before turning on the engine starts it on the first try.
A new trick for this old dog.
Thanks!
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
cold air intake or modified air box? pppt03turbo General Turbo Discussions 17 21 Jan 2006 01:11 am
PTs and the "cold" yukonsly Canada PT Forum 6 30 Jan 2004 04:58 pm
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
Real cold air intake Airbillster Tech & Performance Forum 5 02 Sep 2003 02:26 am
A TRUE cold air intake Airbillster Turbo Performance 7 14 Aug 2003 01:19 pm
