PT Cruiser Forum Car Videos
Custom Wheels
Electronic Boost Gauge
Old 22 Jun 2003, 12:31 am
sakigt sakigt is offline
Send a message via AIM to sakigt
Default Electronic Boost Gauge
Could some one with an EWD for the 03 GT's Please help....need to find a 12v ingnition wire that is hot through start up...alll the ones I have tried loose power once I try to start the car. The new Autometer C2's need a constant 12v signal from when you turn the key to the accesories to start up....can someone please help.....only thing i can think of is running a wire from the fuse box in the engine bay to the interior, but I don't want to have to that. Will post pics soon. Also I know you already posted how to hook up a turbo timer, If you could point me in the right direction to hook up my greddy turbo timer, would be mucho apreciato.......[8)]
Old 22 Jun 2003, 10:29 pm
Anyone? [:I]
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 22 Jun 2003, 11:32 pm
Dalite Dalite is offline
Using the inside fuse box, below and to left of steering wheel, you can use: 5,6,7,9,10,11,12, 14 and 15. Fuse descriptions (brief and cryptic) are found on the back of the fuse panel cover.
5,6 & 7 are Ignition Switch Output (RUN)
9, 10, 11 & 12 are Ignition Switch Output (START/RUN)
14 & 15 are Ignition Switch Output (RUN/ACCY)
The auto parts stores carry a fuse tap that slides over one leg of the mini fuse and gives a male spade terminal to connect to, so you don't have to cut into any wires.
Hope this is what you are looking for..
Old 23 Jun 2003, 11:34 am
Gear_Head Gear_Head is offline
Pep Boys also sells an Add a circuit accessory. This is a dual fuse holder w/a pigtail for the added circuit. This enables you to fuse BOTH circuits w/separate fuses. I have used these successfully, and the added fuse is an extra safety precaution.
Alan
Old 23 Jun 2003, 06:26 pm
I'll try it and see....I hope its what I want too [B)]
Old 25 Jun 2003, 12:08 pm
You are correct, sir [|)]
vB code is On
Mopar Boost Gauge install question ksquared11 General Turbo Discussions 1 19 May 2004 02:05 am
boost gauge DREAM2 Turbo Performance 5 16 Mar 2004 01:46 am
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Final manual boost controller installation Ian-PT-GT Turbo Performance 83 10 Jul 2003 11:57 pm
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
  Gas Suppliers | Plastic Surgeon | Remortgages | Loans | Online Loans
