PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
180 degree thermostat question
Old 25 May 2007, 12:52 am
moparbbad moparbbad is offline
Default 180 degree thermostat question
im looking for a 180 degree thermostat but cannot find where to purchase one at can anyone help me out on where to find one, for a 2003 gt turbo pt cruiser. i bought a jet chip stage 2, and it tells you to run a 180 degree thermostat. i see where alot of guys are running one on here, but i cannot find one at an autoparts store they only carry 190 degree thermostat.
Old 25 May 2007, 09:12 am
littleblueGT littleblueGT is offline
Default Re: 180 degree thermostat question
Stant #13788, get it at Pepboys, Kragen, Autozone etc. Be careful with the OEM seal as the new stat doesn't come with one. You will also have to notch the stat in three places (same as OEM stat) to fit the seal, and drill a 1/16" air bleed hole. A turkey baister( squeeze bulb on a tube) works very well in removing coolant.Put the coolant into a container, and remember what ever you took out has to go back in. Allow plenty of time during refill of coolant to purge the air, or you will over heat.
Old 01 Apr 2008, 03:52 am
88budman 88budman is offline
How does your car run with the Jet Chip. I was thinking of getting one but wanted to see how much difference it actually made before spending the money.
Old 01 Apr 2008, 02:34 pm
Mean Green Mean Green is offline
Not even close to the Mopar Stage 1. Even though the Mopar Stage 1 is more expensive it is the building block to more power. With the Jet chip you will still get an overboost code if you try and raise the boost even to 15 psi (Mopar Stage 1 level). With the Mopar Stage 1 you can raise the boost to 18 psi and get no code and have enough fuel to do so.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 02 Apr 2008, 06:15 pm
Dream4's Avatar
Dream4 Dream4 is offline
Here is one that will fit right in with out any modifacation, I have one and it works great, I just need to get a SCT flash unit to change the cooling fan set points in the PCM to match the 180 t-stat.
Darrell Cox Racing - 180 Degree Thermostat (Powered by CubeCart)
I also agree with MeanGreen about the Mopar Stage 1 over the Jet, I know several who sold the Jet to get the Mopar kit after the disappointment in performance, especially if you have an Automatic transmission as the Mopar Kit improves the shifts along with engine performance.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
vB code is On
Stupid question umaxman General PT Cruiser Discussions 11 18 Jun 2004 09:38 pm
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
Stage 1 kit question DREAM2 Stage Turbo Kits 5 17 Apr 2004 10:59 am
Newbis question - Door Locks... patbluecruiser General PT Cruiser Discussions 9 14 Apr 2004 11:39 am
Question after installing speakers in front doors wyzard Sound and Security Forum 3 09 Apr 2004 01:10 am
  Outsourcing | Secured Loans | Credit Cards UK | Loans | Facebook Proxy
