Looking to replace plugs and wires and found this: is it true?
Old 29 Jun 2007, 05:02 pm
Default Looking to replace plugs and wires and found this: is it true?
I was searching the web for spark plug wires for my 03 GT and came across this on this website: replacement.autopartswarehouse.com
"This wire set contains only two wires (for #1 and #3 cylinders). Cylinders #2 and #4 each have a coil connected directly to the spark plug, so ignition wires are not necessary for those two cylinders."
Is this true?
Old 29 Jun 2007, 06:40 pm
Dream4's Avatar
Default Re: Looking to replace plugs and wires and found this: is it true?
Is this true?
NO,there are 4 wires on all PT 2.4L engines, there is one coil with 4 plug wire terminals, and a power connector from the PCM.
That page is wrong, look at the '04 or '05 page they are the same parts as you need:
Chrysler Parts 2004 PT Crsr Turbo Chrysler Ignition Wire Set
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
Old 29 Jun 2007, 07:34 pm
Thanks for the quick reply. That info didn't seem right but I wanted to make sure first.
Thanks again.
Old 02 Jul 2007, 05:02 pm
apexanimal's Avatar
Send a message via AIM to apexanimal
Is this true?
whoever wrote that should be punched in the ear, and beaten with a bronze statue of plato...
'03 GT 5spd: Stage 1+
http://www.cardomain.com/ride/2272425
http://www.ptboutique.com
Old 03 Jul 2007, 06:57 pm
Gold GT's Avatar
<----- enough said!
'04 Gold GT 5spd (there is no other way)
Mopar Stage 1 upgrade, Mopar BOV Conversion, AEM CAI, High Flow Haynes Plastic Intake Manifold, MSD High Voltage Ignition Coil Pack, MagnaCore Spark Plug Wires, AutoMeter Boost Gauge, Greddy Oil Catch Can, Hurst STS... Plus a much longer wish list
I DO ALL MY OWN WORK!!
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
3/25/05 UPDATE - DONE! - New Plugs and Wires NGK BumperBob Tech & Performance Forum 14 31 Mar 2005 01:06 am
