new here to the forums
i went to the track this week and ran my GT my best run was a14.4 at 96 mph-had horrible reaction times though. my problem was i spun the wheels thru 1st and 2nd and i also have an auto stick. i put on new tires and rims last month i have 245's on an 18'rim , we thought that would solve it but it didn't. i guess i need aa set of slicks. Can anyone give me some advice on getting the rubber on the ground, to get better traction so i can get my 0-60 under 2 seconds. i will appreciate your input thanks |
besides your wheels is your pt stock? also were you using the autostick or just kept it in drive?
everything i've done is just add on stuff and i was in auto stick but let the car shift itself
cat back exhaust-mandrel down pipe and bov-manual boost controller-cold air intake-lowering kit
you can view pictures at http://fototime.com/inv/E499E845E668AFF kruzzinpt |
I had the same problem but I adjusted my launch from the line.
I used to load the converter and spool up the turbo, this would give me horrible 60' times. I have learend that the best launch for our car was straight from idle. This way the Turbo lag would help you start to move the car and then jump forward. Ian
i also tried that too, but i still spun the tires. i started from idle then mashed the pedal but still spun. i tried to wait until second and the same happens. what has your best times been and whats your 0-60 times. when did you go full throttle
Did you drive through the water box before you ran? I know it's a dumb question, but if you did, this would explain excess wheel-spin.The key is definitely getting the 60' under 2.0. When I did this on the two Dakota R/Ts I used to have, the ET dropped by more than half a second.
Slicks are the best way to go, but you really really have to heat them up, and I'm not so sure the transaxle and axles would appreciate it very much. TripleJack
![]() ![]() \"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\" Benjamin Franklin, Historical Review of Pennsylvania, 1759 www.cybermopar.com TripleJack |
no i did not go thru the water box, and thats not a dumb question, because i asked that before i went to the track. i'm not worried about my axles, i have already upgraded my axles, they can handle 500 hp and over 500lbs of torque, at least thats what the spec sheet states.my gt has alot of torque im told and thats the problem .
i still am leaning towards a set of slicks, i think that maybe my only option at this point if i am going to get to the 13's (hopefully )
kruzzinpt,
Where did you find the upgraded axles and how much does that run? Did you notice if the axles were of equal length?
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300. |
i found a place in ny called the driveshaftshop.com-the axles costabout699 for the set.they are different in length and the passengers side is a one piece not 2 as stock is.but be care full they sent me the wrong ones twice.talk to frank
Did you notice more torque-steer when you went from the 2-piece to the one-piece pass side axle? That's how Chrysler and Shelby lessened the torque-steer on the 2.2/2.5 turbo cars, by going to a half-shaft design.
| Turbo light to track | nuke72 | General Turbo Discussions | 3 | 26 Jul 2004 12:19 am |
| Recommended warm-up time | dbraveman | General PT Cruiser Discussions | 9 | 12 Feb 2004 09:38 am |
| Lots of Fun At the Track Last Night | FRM3 | General Turbo Discussions | 9 | 16 Dec 2003 05:12 am |
| TRACK DAY IN ONTARIO | Ptturbine | Canada PT Forum | 4 | 24 Sep 2003 07:42 am |
| Won't start first time | Mike Radowski | Turbo Performance | 1 | 14 May 2003 02:34 pm |
