PT Cruiser Forum Car Videos
Custom Wheels
Ye Olde Intercooler Observations
Old 30 Jun 2003, 12:10 am
CraigO CraigO is offline
Default Ye Olde Intercooler Observations
Seems as if the engine fan does a great job of cooling the intercooler - it never gets hot while at idle with the AC on (engine fan is on at this time) Perhaps we don't need IC fans after all like I thought and posted a few weeks ago!
Craig
Old 30 Jun 2003, 05:32 am
flashbk2 flashbk2 is offline
I beg to differ on that point if you think having the water temp climb to 215 degrees in traffic before dropping back @ road speeds to 195 is good ?
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 30 Jun 2003, 10:23 am
TripleJackInGA TripleJackInGA is offline
I'll be picking up a 180 degree thermostat this week. It allows the engine to run just a tad cooler, and it's cheap.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 30 Jun 2003, 11:13 am
RobGT RobGT is offline
The cooler, the better, my $.02...
Jeff will a fan fit behind the xenon fascia?? No room w/stock.
Oh well, looks like i have no choice but to get that R/S front end!!
http://www.californiacruisers.com/frontend_cq.htm
Click to see my GT!
Old 30 Jun 2003, 11:24 am
Dalite Dalite is offline
TripleJack,
I go along with your reasoning on the lower temp thermostat. However, don't expect it alone to be able to let the engine run cooler temps. The PCM controls the electric cooling fan, and it won't let it/them come on until the temp sensor (or what ever sensor it monitors the water temp with) tells it the water temp matches the parameters set by the original configuration for the stock t'stat.
I had made a suggestion to Mopar Performance that they solve the thermostat o-ring replacement question on the Stage I upgrade by including a lower temp t'stat and progamming the PCM to let the fans come on earlier, but I guess that idea was shot down.....
Let us know if you see any difference on the gauge or performance with the 180 degree replacement..
Old 30 Jun 2003, 02:54 pm
"I beg to differ on that point if you think having the water temp climb to 215 degrees in traffic before dropping back @ road speeds to 195 is good ?"
Huh? What I said was the ENGINE FAN DOES A GREAT JOB OF COOLING THE INTERCOOLER. And it does. P l e a s e do not misquote or twist the reply.
Craig
\'03 Tangerine Dream Cruiser - Chrome Beltline kit, AMP Billet fuel door, chrome grill kit, H&R Sportline lowering springs, PT-Tuning straight thru exhaust, Hallman boost controller & stage one with Mopar blow off valve kit - 240 hp+
Old 30 Jun 2003, 03:02 pm
Kirby Kirby is offline
Be careful with that low temp thermostat, sometimes the 195 degrees is important for combustion temps, and whether it's 180 or 195, wide open cooling(when the thermostat opens) in hot stop and go trafic is the same, wide open.
Do you think that a low temp thermofan switch might be more helpful?
Old 30 Jun 2003, 03:14 pm
Craig I'm sorry I misinterpreted your post...it's great the fan cools the intercooler ! However it doesn't really stand up to the task of cooling the motor efficiently as I've seen it ! I guess that having the intercooler cool is more important than the engine operating in optimum range ! [:I][xx(] If you really want to know what's going on inside the engine invest in a mechanical water temp gage....you'll be in for some surprises.....
Old 30 Jun 2003, 03:36 pm
sfhickey sfhickey is offline
CraigO. These are friendly forums, every post I've read of yours has a harsh tone. Remember, we're all friends here!
Black 03 GT - silencers removed. PT Cruiser 3BL. Much more to come
Old 30 Jun 2003, 05:02 pm
OurPTGT OurPTGT is offline
I got my I on that one also Rob.[|)] Anyone buy from CalCruisers?
I like the MIRAGE also[:X]
vB code is On
BOV before or after Intercooler PT GT Turbo Performance 9 30 Jun 2008 04:46 pm
intercooler to throttle body pipe CJJ Turbo Performance 2 22 Jun 2004 12:51 pm
intercooler sprayer cpalm1 Turbo Performance 16 05 Apr 2004 09:08 pm
bigger opening for the intercooler got turbo Exterior & Interior Styling 0 23 Feb 2004 09:50 pm
Intercooler Fan Mod RobGT Turbo Performance 18 12 Jun 2003 12:21 pm
  Watch Naruto Online | Problem Mortgage | Ipod nano | Equity Release | Auto Loans
