PT Cruiser Forum Car Videos
Car Rims
I removed the silencer in pipe from airbox to turbo - what is that noise
Old 14 Oct 2007, 04:40 pm
mino mino is offline
Default I removed the silencer in pipe from airbox to turbo - what is that noise
i cut open the oem pipe from the airbox to turbo and gutted out the perferated baffle . than i used a rubber coupler to re-join the two parts together with hose clamps . after several mile of driving ( to allow the computer to get used to the new airflow , THE CAR RAN STRONGER and boosted harder . WHAT is the pssst sound after i LEAVE OFF the gas ? maybe the blowoff ? wastgate ? - what is the thermostat valve housing attached to turbo - or is the sound just the turbo winding down ( i hear the high pitch whine on acceloration , but this sound is more of a lower releif valve sound
Old 14 Oct 2007, 05:02 pm
Mean Green Mean Green is offline
Default Re: I removed the silencer in pipe from airbox to turbo - what is that noise
You are hearing the factory surge valve blowing off. It releases back pressure to the turbo.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 14 Oct 2007, 06:50 pm
thanks for the reply - we all appriciate your sharing of knowledge on cars - so that sound was hidden by the baffle i took out ? does that mean the pressure valve dumps air back into the tube in reverse order and the sound was mufflered out . anyway , if it is a normal functional sound that is suppose to happen it is fine to hear it by me . even though i opened the pathway to the turbo significantly ( i used a dremel with some cutting tips and grinding tips, then sanded and polished to a smooth bore ) it still has a choke point of about 1 3/4 " in two areas , but i think this is better than a 1 3/8 " full running 6 inch muffler ( i learned this from port designing in speaker building) . but he bottom line is THE CAR IS ( seems to be ) more stronger and better boost power - PS hoe\w long does it take for the computer to adjust for mods and does your style of driving ( engaging the boost alot ) affect computer programing ?
Old 14 Oct 2007, 09:57 pm
It's not hard to make a turbo to airbox hose. The hose starts out at 3" and tapers down to 2 1/2" so you haven't really opened it up enough. I made mine. Or you can but the hose from a guy who makes them.
vB code is On
airbox to turbo pipe - does change help on stock gt mino General Turbo Discussions 1 18 Oct 2007 06:14 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Turbo noise sawdust123 General Turbo Discussions 19 28 Mar 2005 01:35 am
turbo silencer ring JWC94 General Turbo Discussions 2 10 Apr 2004 02:36 pm
Turbo Up Pipe Mean Green Turbo Performance 5 04 Jan 2004 05:11 pm
  Problem Mortgage | Car Insurance | Montana Music | MPAA | Web Advertising
