PT Cruiser Forum Car Videos
Custom Wheels
New Mopar Gauges (info and brochure)
  #11 (permalink)
Old 08 Jul 2003, 06:24 pm
COP TZER COP TZER is offline
hmmm...they look like rip off autometer gauges, and they're probably more expensive too b/c they're "mopar"
My Cruiser is slow. I love the law.
  #12 (permalink)
Old 08 Jul 2003, 07:46 pm
tthrift tthrift is offline
Send a message via AIM to tthrift
i'll try to answer all questions
1. PRIMOX, low voltage? i don't know. they conect to the o2 sensor thats all i know so far
2. DCG333, no one can purchase these gauges for a better deal like summit racing,jegs or any other dealer. there will not be anyone selling these gauges for 25% off there isn't that kind of mark-up in them,
3. DTs PTGT, Mopar will be selling guage pods soon, i don't know anything about them yet color, double or triple? when i hear i will post info
4. PeTe, i have not installed my gauges yet so the color is a ?. will post when they are installed.
5. COP TZER, not a rip off autometer, they are autometer gauges plus more of the stuff you need to install them properly.for example my boost gauge comes with a gauge, wiring harness, mounting hardware, wire loom, a map sensor, all the vacuum tees and plugs needed, and full instructions. i believe autometer gauges only come with a guage in a box by itself. that explains the higher price (you pay for what you get)
thanks tommy
  #13 (permalink)
Old 08 Jul 2003, 09:22 pm
quote:Originally posted by tthrift
quote:Originally posted by bigdogdad
On page 2 at the bottom it says for 2002 and older only. Is that a typo on their part? Even though, I am sure the gages would do fine on 2003 models also. Again, a phone call is all it would take. Talked myself into it, I'll call the parts department later today if time permits.
I spoke to autometer about this and i was told that the only guage that won't work on 2003 cars is the (air-fuel ratio guage) HOWEVER if you have 4 wires or less on the upstream o2 sensor it will work if you have 5 wires or more on the upstream o2 sensor it won't work.
So we should be fine for the gt cruiser i counted my wires and there are only 4 wires.
I have these guages and they come with more than just a guage in a box, they have everything you need. the best guage pkg. that i have ever seen, i am installing them as soon as my triple guage pod arives.
thanks Tommy
new news on air fuel gauge at this time the guage willnot work on our gt cruiser. will post when i have new info.
tommy
  #14 (permalink)
Old 09 Jul 2003, 03:14 am
From what i've experienced, all my precious autometer gauges have come with all the hardware i needed...i had a triple pod in my '01 (volt, vac, oil pressure) and a double pod (A/F, boost) in my VW. But it's good to see mopar using a well respected aftermarket company. If they're licensed by automete why is there no badging on the gauge face [:I]
  #15 (permalink)
Old 09 Jul 2003, 09:45 am
DTs_PTGT DTs_PTGT is offline
COP TZER,
Maybe they wanted the Mopar logo on the face instead? The second link, which is the price sheet shows that you can get the Mopar logo on Carbon Fiber, White of Silver faces, or the SRT logo with a Silver face.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
  #16 (permalink)
Old 09 Jul 2003, 10:00 am
TripleJackInGA TripleJackInGA is offline
For the same reason that you PT isn't called a Neon. Sure, it's built on a Neon platform, but that's not what it is, and Chrysler sells it instead of Dodge.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
  #17 (permalink)
Old 09 Jul 2003, 10:07 am
Dalite Dalite is offline
The O2 sensor used on the GT has a 2.5 volt offset that gives a reading of 2.5 Volts to 3.5 Volts at the gauge. The standard A/F gauge is looking for the same 1 volt variance; minus the 2.5 volt offset.
To make this gauge work in the GT, you would need to get a bung welded into the exhaust (downpipe) and use a industry standard .1 to 1.0 volt O2 sensor.
An inexpensive one like the one used in the 91 Shadow has been recommended to me by at least one vendor when I was researching this earlier.
When you go to a separate O2 sensor, you loose the stability of the pre-heated, widebabd sensor that the GT uses.
I am hoping that Mopar will come up with a "Y" harness that allows the stock sensor to send data to the PCM on one leg of the "Y" and a signal (minus the 2.5 volt offset) to the gauge on the other leg of the "Y". Otherwise, we will have to sacrifice some of the stability of the new generation sensor and resort to old technology and "porcupine" the system with an extra sensor.
It would heve been easier for Mopar to tap off the PCM input with a gauge designed to read the raw data from the O2 sensor(s) and give an accurate reading; an approach I hope they will eventually consider....
vB code is On
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
  Credit Cards | Mobile Phones | Credit Card | Loans | Myeeos layouts
