PT Cruiser Forum Car Videos
Custom Wheels
N1 Catback Exhaust
Old 03 Jan 2008, 12:43 am
cdd cdd is offline
Default N1 Catback Exhaust
Well I decided I wanted a larger exhaust but didn't want to spend a lot of money. Could not find out much about the N1 Exhaust systems listed on Ebay. Bid low $75 on the one listed make an offer and it was accepted. Installed kit at home. The muffler sits a bit lower than the BTG Gen-III Ultra-Performance Cat/Back System but I couldn't beat the price. May relocate can later. Sound clips.
4shared.com - online file sharing and storage - download PT N1 IDLE.MOV
4shared.com - online file sharing and storage - download PT N1 FLOORED.MOV
Auction link.
eBay Motors: N1 CATBACK MUFFLER EXHAUST 99-06 CHRYSLER PT CRUISER 01 (item 320178000171 end time Jan-31-08 15:16:16 PST)
2004 PT PLATINUM
Auto,S1,Air box mods,removed abtt silencer,boost gauge,S2 wastegate, 15.58@88.9mph
Old 03 Jan 2008, 12:57 am
cdd cdd is offline
Default Re: N1 Catback Exhaust
Didn't want to attempt to try to install the 3"o2, dp, and cat so I took it to my favorite muffler shop and let him deal with it. Having a lift and proper tools makes the difference. Took him around 2 1/2 hrs to complete. Had typical problems most people see, top bolt on dp wouldn't loosen all the way(cut off), lower heat shield in the way(told him ok to trim).
Took some pics of the stock stuff that came off. I had heard that pipe was measured by od. Stock pipe has a 2"id, 2 1/4"od.
2004 PT PLATINUM
Old 03 Jan 2008, 01:31 am
cdd cdd is offline
Bought the 3"o2, dp, and cat from ebay. Links to auctions:
eBay Motors: Dodge Neon SRT-4 srt 4 MPx 3 inch O2 housing (item 130171000897 end time Nov-05-07 22:35:55 PST)
eBay Motors: SR*S DOWN PIPE DOWNPIPE 03 04 05 DODGE NEON SRT-4 03-05 (item 320193438276 end time Jan-06-08 17:10:18 PST)
eBay Motors: 3" Catalytic Converter High Flow Stainless Steel (item 130183537032 end time Dec-24-07 15:08:58 PST)
Had the muffler shop cut the dp and weld in the cat.If I had known the o2 port on the dp was too far for the stock wiring to reach after cat was installed (SRT-4 dp a little shorter than the PT dp) I would have bought the cat with o2 port on it that was a few dollars more. Had all of this welded to the catback system. Also had the shop remove the clamps and weld all joints on the catback system.
pics of 3"o2, dp, and cat
Got the dp with a make an offer option of $65
2004 PT PLATINUM
Old 03 Jan 2008, 01:47 am
Mean Green Mean Green is offline
Auction link.
Looks good, sounds good. Hope that is a flow through muffler. Turbos hate a restrictive exhaust system. Don't believe the "up to 10 hp increase". A bigger exhaust, if it is flow through, will allow your turbo to spool up faster and get to your power quicker, but will not increase hp. If you want an increase in hp you need to go aftermarket on the o2 housing (3") and the downpipe (3").
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 03 Jan 2008, 02:25 am
cdd cdd is offline
Muffler is straight through, no turns.
2004 PT PLATINUM
Old 03 Jan 2008, 02:46 am
That's a very good thing.
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Catback Exhaust mbehr55 Tech & Performance Forum 6 14 Jun 2005 04:55 pm
Heartthrob catback single exhaust Back Order Mean Green Turbo Performance 0 04 Feb 2004 02:14 am
Free Catback Exhaust for SoCal owner(s)? Big Al General Turbo Discussions 6 19 Sep 2003 02:14 pm
  Credit Cards | Mortgage Loans | Loans | Myspace Layouts | Loans
