PT Cruiser Forum Car Videos
Custom Wheels
50HP Nitrous system for turbo
Old 11 Jul 2003, 11:45 pm
Jeff V Jeff V is offline
Default 50HP Nitrous system for turbo
I'm no motor-head, so can those of you in the know confirm or deny whether this can be done safely (or at all) on a GT?
http://cgi.ebay.com/ebaymotors/ws/eB...m=2422963 905
[8)]
Old 11 Jul 2003, 11:58 pm
flashbk2 flashbk2 is offline
It can be done AT58 is running 75 hp on his GT . However I believe to do it right/safely the total cost will be over $1000.00 AT58 had MX5 help get it working correctly and dyno'd it .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 12 Jul 2003, 09:38 am
TripleJackInGA TripleJackInGA is offline
Yeah, you can't just get the basic kit.You need to have bottle warmers, blow-down tubes, purge valves, fuel-pressure cut-off switches, etc. to make it truly safe, and even then it's a stretch.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 12 Jul 2003, 10:35 am
MX-5 MX-5 is offline
Hold on!!!!!
I've posted about this guy before!
In fact, I've instaled Edelbrock nitrous kits, but not for a PT.
That's a DRY kit! Stay away!
Here's a quote from the auction:
"The extra fuel is generally supplied through the injectors by raising the pressure or changing the duty cycle. Dry nitrous systems are the SAFEST and most RELIABLE way to get power gains"
There is no way to increase the fuel with the PT's returnless fuel system. The regulator is inside the fuel tank. You MUST use a wet kit. This means that fuel and nitrous are added together to increase power.
The most popular and PT specific kit is from NitrousWorks.
Here's an online install guide:
http://www.ptdoityourself.net/ptnitrousguide.html
Yes, you can shoot at leat 75hp on top of the turbo.
I'm a little over 100hp on my N/A PT, but that's the limit.
Old 12 Jul 2003, 12:27 pm
Ian-PT-GT Ian-PT-GT is offline
If you want an NOS kit go with the ZEX kit for the PT.
http://www.zex.com/
It is a "Wet" Nitrous system. It includes an electronic controller and uses the TPS as a reference in order for it to supply the Fuel and NOS mixture proportionally, not in full blast in one shot. They claim it is the safest system on the market because it measures the nitrous and adds fuel to compensate and both come out thru one injector at the intake.
It is a "Wet" system because it supplies the fuel also thru the intake manifold and no adjustments need to be done to the injectors or factory computer.
Old 12 Jul 2003, 10:06 pm
COP TZER COP TZER is offline
yep...Zex is the only way to fly...either that or VENOM....mmmm...man is that a sweet kit, if inly it was cheaper.
My Cruiser is slow. I love the law.
Old 14 Jul 2003, 04:55 pm
At58 At58 is offline
Yes I have a NitrousWorks wet system on my GT. I have it set up for 75HP and it seems smooth there. Ran the fuel line into the end of the fuel rail and the injector is mounted in the rubber hose just in front of the intake. I am quite happy with it and so far no problems. Also I should say I don't run a warm blanket or purge system so my total cost was around $500.00 shipped and installed.
2003 Inferno Red GT with a few chrome goodies.
Old 19 Jul 2003, 04:47 am
AA PT AA PT is offline
Here's a copy of my email to Edelbrock and their response regarding the dry nitrous system and our GT turbo with and without the stage 1:
-----Original Message-----
From: GoodwinJRandy@cs.com [mailto:GoodwinJRandy@cs.com]
Sent: Saturday, July 12, 2003 1:18 AM
To: edelbrock@edelbrock.com
Subject: nitrous kit #70600
Will kit # 70600 work on the 2003 TURBO GT PT Cruiser? Chrysler just came out with a stage 1 kit. Will it work with the kit?
Thank you.
Subj: RE: nitrous kit #70600
Date: 7/15/03 3:23:02 PM Pacific Daylight Time
To: GoodwinJRandy@cs.com ('GoodwinJRandy@cs.com')
#70600 is for a non-turbo PT Cruiser.
An experienced professional could make it work, just make sure that the fuel system is up to the task. We don't recommend it, but the choice is up to you.
Please send any replies to mlin@edelbrock.com
Include a copy of this entire e-mail with your reply in order to help our technical representatives help you more thoroughly.
Thank you.
Sincerely,
The Edelbrock Tech. Dept.
Old 19 Jul 2003, 10:00 am
Randy,
(are you part of Goodwin racing??)
http://www.good-win-racing.com/goodwinracing_002.htm
Let's ask Edelbrock EXACTLY how they plan to get more fuel into the PTs engine to make up for a dry nitrous kit?
Other than an aftermarket (expensive) fuel pump, I cannot see what they have in mind.
You need a metered and regulated fuel supply to add to the nitrous to make it work. The power comes from the fuel. Nitrous is non-flammable.
Turbo PT or regular PT, you need a wet kit.
Adapting generic kits like ZEX, Venom, or Edelbrock is a pain in my ass. The NitrousWorks kit is made for the PT. Not cutting or adapting the kit is needed. Everything is made to fit. Beware that the NitrousWorks kit for the Neon is different. Be sure to get the PT kit.
Search for bottle refills here:
http://www.holley.com/HiOctn/ProdLin...S/NOSlist.html
Old 20 Jul 2003, 05:46 am
MX:
Nitrous oxide is just that, lotsa oxygen. That's why fuel needs to be added, or you've got a blow torch.
To answer your question, I have my own TA/FC team that's been idle for the last 2 years. Here's a pic:
http://www.dragracecentral.com/DRCPh...r1999#indextop
And I currently own this car:
http://www.dragracecentral.com/DRCPh...r2002#indextop
And I am responsible for this car:
http://www.dragracecentral.com/DRCSt...-DA63E9120BED&
But I'm not related to the Good-Win racing guys you mentioned.
We run methanol alcohol with a PSI screw supercharger putting out about 50 pounds of boost. We've run a best of 5.64 seconds at 255 miles per hour.
Randy
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Inilex Satellite Tracking System for PT Cruiser Tee It High General PT Cruiser Discussions 4 18 Jan 2005 11:47 pm
Nitrous users! Important news for auto trannys MX-5 Tech & Performance Forum 11 08 Jan 2004 07:31 pm
  Credit Counseling | Web Advertising | Adverse Credit Remortgage | Loans | Buy Anything On eBay
