Is it a turbo or a turbo lite?
Old 28 Feb 2008, 11:47 pm
AlexJB's Avatar
Send a message via Skype™ to AlexJB
Default Is it a turbo or a turbo lite?
Hi folks,
I've just bougt into the PT family with a 2003 PT GT.
I've driven it no more than a test drive and pick it up tomorow but it seems to go just fine, quite a bit quicker than the N/A 2.4 auto I drove earlier in the week.
It has an aftermarket boost gauge fitted and was making 9/10psi is this a turbo lite?
I used to run a tiny ford at home in the UK with 5/6psi without intercooler so 9/10psi with an intercooler and other gubbage to suit seems low for a full power turbo.
Please put me straight!
To be old and wise, you must first be young and stupid.
Old 29 Feb 2008, 12:33 am
SRG SRG is offline
Default Re: Is it a turbo or a turbo lite?
In 2003, Chrysler came out with the PT Cruiser GT. It had the 220 hp 2.4 L turbo charged engine. In 2004 Chrysler came out with the 180 hp turbo charged 2.4 L engine which was available on non GT (touring and Limited editions???) PT's.
The 180 hp turbos can run on regular gas, as opposed to the Gt's which Chrysler recommends premium fuel. The only difference between the 2 engines is the computer programming.
The 2004 GT's were labeled "High Output"
Good luck with your new GT.
srg
Old 29 Feb 2008, 02:51 am
215 hp for the '03 GT. I had one and modded it up to 280 hp.
Your boost will be affected by colder weather. Where stock boost is 13 psi when it is colder you'll boost only 10-11. Also check for boost leaks. You can zip tie all vaccuum hoses and put t-bolt clamps on intercooler hoses and the hose that runs from the airbox to the turbo, turbo side. Both my '03 GT and my '05 SRT-4 had boost leaks straight from the factory.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 01 Mar 2008, 12:14 am
AlexJB's Avatar
Thanks chaps.
Picked up the PT this lunch time, only done about 60 miles in it but I'm loving it so far.
TURBO LITE VS GT 1MEAN PT Stage Turbo Kits 12 02 Jul 2004 09:37 am
GT vs Turbo lite parts? Jimbo General Turbo Discussions 10 11 Apr 2004 11:03 pm
Turbo Lite w/5-spd? TomCatMi General Turbo Discussions 2 21 Mar 2004 10:21 pm
Auto Stick and The 180 HP Turbo "Lite" FRM3 General Turbo Discussions 5 26 Oct 2003 04:00 pm
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
