Premium Fuel
Old 16 Jul 2003, 10:50 pm
Default Premium Fuel
We know that Chrysler recommends premium fuel. Apparently the anti-knock sensor will retard timing or reduce boost, thereby reducing performance.
Has anyone actually documented these reductions? I know it seems slower, but can we show it by the numbers?
Old 16 Jul 2003, 10:58 pm
I know I will be corrected if wrong, but isn't the octane rating only an indication of the anti-knock quality of the fuel?
In other words, the higher the octane (in the range of 87 to 93) the less chance of knock. In our case, that would equate to a higher probability of optimal performance with 93 than produced while using a lower octane.
If we could ever get some kind of data logger that is compatible with our systems, we would be able to measure and find out for sure...
Old 17 Jul 2003, 12:43 am
I always put the highest availible in. I think you are right tho, Dalite. I could see no reason why it would not.
Old 17 Jul 2003, 12:58 am
i got screwed once on a road trip at a gas station that RAN OUT OF PREMIUM!!?? I had to settle for the mid range crap, and boy did I feel a difference. It felt like I was driving around with the A/C on full blast and a garbage bag rapped around my intake cone
My Cruiser is slow. I love the law.
Old 17 Jul 2003, 01:00 am
That sucks!! I hope I am never in that situation!
Old 17 Jul 2003, 11:18 am
I was in Vegas over the weekend, a couple 76 stations where I was getting gas, had competition fuel available, 100 octane. I didn't have my GT with me but it was like $3.95/gal. How would that help/hurt the engine. I figured you would need high perf spark plugs, wires. What else?
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 17 Jul 2003, 11:24 am
i use 92 oct all the time,( thats when my car is running right) that 100 oct im not sure what it would have done
Old 17 Jul 2003, 11:46 am
Send a message via AIM to Steve03GT
As Dalite noted, octane (or octane number) is defined as a number that measures the ability of a liquid motor fuel such as gasoline to prevent preignition or knocking. Fuels with higher numbers are less likely to cause knocking; conversely, the lower the octane number, the more energy (btu)per unit, which is why using a higher-than-necessary octane number (less energy/unit) results in decreased performance.
To answer your question concerning what effect 100 octane would have with your GT Cruiser, if you haven't done anything to increase cylinder pressure, e.g., more boost, timing-advance, or static compression, I suspect the 100 octane would hurt performance; this is assuming Chrysler has designed the engine and the PCM to perform optimally using 93 octane. Others feel free to chime in here.
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges
\'02 Corvette (510 RWHP/510 TQ)
Member of 11sec. club &
NRA Benefactor Member
Old 17 Jul 2003, 02:21 pm
According to the owner's manual, the PT is tuned to perform optimally using 91 octane.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
Old 17 Jul 2003, 05:28 pm
Send a message via AIM to PK Cruiser
To bad I can't find any 91 octane here...closest is 89...I use 92 or 93 depending on when I need gas, which station I'm closest to...
\'03 Black Turbo, Autostick, Removed Intake Silencers, K&N Drop in Filter, MOPAR BOV, Eibach Springs, Kenwood CD/MP3 Player & amp, 12 inch Sub...soon to be a member of the Stage I club...
All 2002 Cruisers Recalled??? zzzhuh General PT Cruiser Discussions 18 24 Mar 2004 05:12 pm
Chrysler Introduces Premium Care Plan for 2004 skylight PT Cruiser News and Rumors 1 02 Jul 2003 08:49 am
