PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Oil Catch Can
Old 03 Mar 2008, 02:53 pm
jingks jingks is offline
Send a message via AIM to jingks
Default Oil Catch Can
I have an oil catch tank and I was wondering where install the catch can hoses? I know one goes on the PCV, but I don't know where the other one will go. Does it go on the driver side crack case breather? (the hose that goes to the stock air box) Or on the Intake manifold. And why would it go on the intake manifold if it doesn't go in the crack case breather.
Reason being I'm installing an aftermarket intake on a 04 GT H.O.
Thanks guys!
Old 03 Mar 2008, 03:16 pm
Mean Green Mean Green is offline
Default Re: Oil Catch Can
Thanks guys!
Install the catch can in between the pcv and intake manifold. If you are bound and determined to use a hot air intake then the second catch can goes in between the crank case and the intake.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 03 Mar 2008, 03:26 pm
Would I use a T-fitting to slice into it?
Old 04 Mar 2008, 07:02 am
No. Catch can should have an arrow on it. Cut hose going to the PCV from the valve cover, insert the catch can with the arrow pointing toward the PCV valve.
Old 24 Mar 2008, 12:18 pm
Ok so I installed the Catch can on the crank case breather (from the old air box.) The Second line would go to the PCV? What happens to the inlet for the intake manifold where the PCV connects to? Do I cap that?
vB code is On
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
Flow back catch can littleblueGT General Turbo Discussions 16 30 Jul 2005 10:46 pm
Catch can in quicksilverdon General Turbo Discussions 2 02 May 2005 10:34 pm
Oil Catch Can crazie.eddie General PT Cruiser Discussions 30 30 Oct 2004 06:23 am
Greddy Catch Can crazie.eddie Tech & Performance Forum 10 20 Oct 2004 03:00 am
  Homeowner Loans | Fast Loans | Loans | Free eBooks Download | Free Advertising
