PT Cruiser Forum Car Videos
Custom Wheels
Autometer gauges
  #11 (permalink)
Old 20 Jul 2003, 05:27 pm
PTGT Redman PTGT Redman is offline
Not to sound like a broken record but a few questions:
1. the pick in one of the links showing the point in the exhaust collar for the pyrometer was taken from under the car?
2. I have a vac/boost gauge with MAP sensor. It requires constant power thru start up. If I use the add a fuse piece (which i bought) what is a good fuse to do the add a fuse?
3. I have a pyrometer as well, where can i take power for that and does it require a fuse?
4. Lastly, if i splice the orange wire for use for lighting the gauges, will the gauges switch on with the rest of the dash lights, or do i need to tap into the wire that runs for the dash lights?
Any of u do it yourselfers please give me a hand thax .
Rob
Homepage:
  #12 (permalink)
Old 23 Jul 2003, 06:20 am
THier THier is offline
Redman,
Yes the orange wire will work with the rest of the gauges, dimming ect, that is where mine is tapped.
Tom
  #13 (permalink)
Old 23 Jul 2003, 09:08 am
gsharrock gsharrock is offline
Redman,
If you put the probe for the EGT in the "cuff" after the turbo your temperature readings are going to be possibly several hundred degrees low. The best place is in the exhaust manifold before the turbo. I installed mine like Hector from Exhaust Depot did. See the following pic.
I used a 1" hole saw to drill through the heatshield and then drilled and tapped the manifold for the probe. The probe on my Autometer was 1/8" MPT but since I didn't have a 1/8" PT tap, I drilled and tapped it for 1/4" MPT and then used a 1/4" MPT x 1/8" FPT reducer bushing. Numerous people have expressed concern about metal shavings falling down into the exhaust manifold while drilling the hole and the shavings might be sucked into the turbo damaging the blades. I did not have this problem and in fact, the rotation of the drill bit draws the shavings up to the outer surface where I picked them up with a shop vac.
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC — The WooX 30w x 2 powered subwoofer
vB code is On
Can you say Gauges! Wicked_PT General PT Cruiser Discussions 16 24 Apr 2006 02:57 pm
Stock Looking Gauges 2step Classifieds: For Sale/Trade 1 21 Sep 2005 01:23 pm
aftermarket gauges dfunkdj Turbo Performance 3 08 Jun 2004 10:40 am
Gauges Mean Green Turbo Performance 3 06 May 2003 09:55 pm
Add-on Gauges Help 2K1Cruizer Tech & Performance Forum 2 03 Dec 2001 07:42 pm
  Credit Card Consolidation | Share Prices | Home Loans in India | Mortgage Calculator | Electronics
