PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Stock air intake question
Old 28 Mar 2008, 05:47 pm
rottone rottone is offline
Default Stock air intake question
Hello,
I recently looked at the air intake on my '03 GT. It looks like the input tube to the airbox just sits sloppy over an oval hole from the left fender. On the outside of the wheel well, there is a gap between two pieces of covering that seems to be where outside air would get to the intake. There also is what looks like a small hatch that could be removed to get more air, but it feels like it will break in order to remove it.
Is this the normal setup? If so, what can be done to improve the airflow (besides a CAI) - do people generally put holes in the wheel well fairing to get more air? Does it help to secure the input pipe so it is tight on that oval opening?
I have already removed the baffle and cut down the snorkel inside the airbox. I would also like to replace the airbox-to-turbo pipe, but cannot find one. Any suggestions?
Thanks for your advice.
\'03 Purple GT AutoStick (cloth seats, no sunroof-max headroom),
Crane FireWires, NGK IX iridium plugs, K&N drop-in airfilter, removed airbox silencers, wood dash trim, chrome wheels/grille/door spears/backup lights/tailight trim, fuzzy dice.
Old 29 Mar 2008, 09:14 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Cool Re: Stock air intake question
Four (4) pages back in the threads in this forum.
intake`s
Old 31 Mar 2008, 01:07 pm
Cal Cruzer Cal Cruzer is offline
Default Re: Stock air intake question
I wouldn't remove the cover in the wheel wells, it keeps the crap out. I plumbed a line to the bottom of my airbox from the fron of the car and cut a hole in the bottom of the airbox. I installed a coupling in it and attached the tubing to it. Air directly into the box.
Old 12 Apr 2008, 04:12 pm
mino mino is offline
i am going to put a sponge type self stick weather stripping around the opening to block air from engine bay from getting sucked into crack . as for the ttab turbo to air box tube , i did somthing very unique and effective . i took off old pipe and cut it in half withe a mitre saw and cut the hard round section out of the pipe with the built in baffle. then i put a heavy duty 3" black rubber coupler from home depot on the parts to bridge the gap . seems to flow much better and i can hear my stock blow off valve and wastegate now . and it looks stock . i now am deciding what to do on the inner cooler pipes to harden them .
vB code is On
Data on stock '05 N/A intake Bman05Ltd Tech & Performance Forum 2 30 Sep 2007 12:07 pm
Intake System Question azptcruiser Tech & Performance Forum 34 08 Jan 2004 11:19 am
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
Want To Buy - Stock GT Intake and Stock BOV gsharrock Classifieds: Want To Buy 2 16 Aug 2003 12:08 pm
Air Intake Temp using stock components Dalite Turbo Performance 16 28 May 2003 05:35 pm
  Refinance | Myspace Layouts | Loans | First Time Home Owners | Credit Card Consolidation
