PT Cruiser Forum Car Videos
Custom Wheels
Does your GT. do what mine does ?
Old 19 Jul 2003, 05:17 pm
old head from phila. old head from phila. is offline
Default Does your GT. do what mine does ?
My GT. shifts at 5700 rpms. in drive with throttle wide open,same thing in autostick (Locked in 1st. gear),What good is autostick ? Also my Autometer air/fuel gauge bounces from lean to the high part of stoich as i drive and idle,when i get on it it goes to the low part of rich and as i wind it out it drops to the low part of lean(almost off the gauge) this sounds real bad to me,but it runs good and has a lot of power OLDHEAD
Old 19 Jul 2003, 07:56 pm
SHOVEL100 SHOVEL100 is offline
i noticed about that same shift rpm as you
i do feel the computer sittings on the shift points are a bit on the steep rpm side of things
just about the time my teeth grit it decides to shift
mike
BLACK 03 GT GIBSON EXAUST ESCORT SR7 REMOTE RADAR ALPINE,DIAMOND AUDIO,ROCKFORD,PHOENIX GOLD $YSTEM VIPER REMOTE START ALARM
Old 20 Jul 2003, 07:59 am
NkBkGt NkBkGt is offline
Thanks for the CD shovel
Old 20 Jul 2003, 03:34 pm
Dalite Dalite is offline
Is the O2 sensor installed for the A/F gauge a heated one?
If not, it is responding to both the differences in heat and O2 content.
I am hoping that someone will offer a gauge to make use of the stock O2 sensor, which should give more stable readings. The heated sensors seem to give more stable outputs, from what I have been reading on the forums...
Here is a good thread on the autostick. It may explain some on the shift points under different driving conditions.
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=3005
Old 20 Jul 2003, 04:16 pm
I used the sensor that autometer sells for this gauge,and yes it is heated by the 12v. that is wired to it , But what about yours....OLDHEAD
Old 20 Jul 2003, 04:22 pm
DTs_PTGT DTs_PTGT is offline
My GT shifts right at redline during WOT. It's like hitting the number 6 causes the shift to occur.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
Old 22 Jul 2003, 12:38 pm
Krieger Krieger is offline
Mine shifts around 5400 in D@WOT, and right on th 6k in Autostick mode@WOT.
The autostick shiftpoint of 6k is the better of the 2 for acceleration as shifting at or around peak hp drops you outta the sweet spot.
2003 PTCruiser GT
Mods:!Airbox silencers
K&N Filter(2153)
Autometer Pod - Boost/Vac and Volts
Hallman ES Boost Controller running 12PSI steady 14PSI peak
Old 23 Jul 2003, 09:10 pm
DTS:are you saying in drive and autostick both shift the same at 6000 what about the air/fuel gauges you guys,does it do that mine does ? by the way i am waiting almost 3 weeks for stage 1,can't wait much longer.OLDHEAD
vB code is On
Mine is a TRUE 5-STAR Dealership! Gary04GT Sound and Security Forum 6 18 Apr 2005 03:31 am
Mine burned.... hunters109 General PT Cruiser Discussions 5 05 Jun 2004 01:50 pm
Mine is on it's way!!!!!! Capt Kidd PT Cruiser Convertible Forum 0 05 May 2004 08:37 pm
I got mine! 65 Rambler Lady PT Cruiser Convertible Forum 0 12 Apr 2004 01:39 pm
traction control noise??? mine doesn't do it! pingber General PT Cruiser Discussions 7 13 Jan 2003 11:18 am
  Company Reports | Loans | Loans | Mortgage | Online Loans
