I saw a magazine article that included a dyno test of these wires on a 1992 eagle talon. They added something like 10 hp and 25 ft lbs. Of course this was an older car and the original ground connections were not optimal at the time. IMO these wires dont add any power, they allow the engine to make better use of the power it does have. I dont think it would make as much of a difference on newer cars, as your comments indicate Ian. But still, 25 ft lbs out of ground wires, damn[?]
90 Eagle Talon Tsi AWD - 300 Hp -K&N, 16g turbo, JE pistons, 3in Turbo back exhaust, mild port&polish 03 PT Cruiser GT - 215 Hp-Airbox and Intake pipe silencers removed |
An underdrive pulley doesn't add anything. It just gives back some of what the older pulley took away.
Mike |
Ant
PT powered PT with: Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection |
You would have to be on crack to pay $135.00 for 8gau. ground wire and crimp on connectors. You are looking at about $30.00 cnd. $15.00us in parts. I work for a high end home theater store in Calgary and we star-ground things all the time to get rid of issues. Just good solid core, a few twisted strands are ok, and replace what chrysler installed.
Don
\'03 Inferno Red 5 spd. Hurst shifter,Loaded |
Ant...Mike is correct, they do not "make" power, they free up power that is being lost though parasitic devices that are being driven by the power of the engine. It takes HP to turn the Alternator and water pump (I am using the case of my mustang). Car companies used to rate HP in engines higher because they would dyno them without accesories attached. This is the same effect that UD pullies provide. They turn the alt and water pump slower thus using less power. Some mustangers experienced diminished cooling because the pump was moving slower so we had to put in a bigger alum radiator and your lights would dim just a bit at a 750 rpm idle but they would always dyno out at about 10HP so it was just a trade off.
You are correct, the UDP frees up power. However don't overlook the fact that a majority of the power is gained from less rotational mass (the UDP being lighter than the OEM)not the actual under driving.
There is very little rotional mass in pullies. You will reduce rotational mass with a lighter flywheel that can be measured in pounds, but with pullies were are talking ounces. No, parasitic loss is what the smaller pullies address. The engine just does not have to work as hard turning these items.
This is just a snippet from a very simple search on the subject. Quote:
or another article here: http://www.sportruck.com/howto/highw...rive%20Pullies I will be willing to read any research on the subject that specifies gain from reduced rotational mass of underdrive pullies.
ok, so the concensus is that the UDP may very well help without reducing coolant flow. The big question is then does anyone have a part suggestion?
\"If your gonna be a bear BE A GRIZZLY\" |
i believe that either www.modernperformance.com or www.howellautomotive.com have some in stock
My Cruiser is slow. I love the law. |
