PT Cruiser Forum Car Videos
Car Rims
Mopar BOV
  #21 (permalink)
Old 13 May 2008, 04:01 pm
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: Mopar BOV
I put the BOV on my wifes Cruiser and she love it.
it still pulls hard but they do tend to leak, ive seen it on my SRTs block off plate, and on some other local guys SRTs, some copper RTV fix that.
the 3rd bolt is easer to get to on the Cruiser than on the SRT-4
it only took me 20 min to change it.
I still need to Boost leak test her car but wont be able to do it for a while works been getting more and more busy.
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
  #22 (permalink)
Old 13 May 2008, 07:14 pm
dc3_1132's Avatar
dc3_1132 dc3_1132 is offline
Is your wife's PT an auto or a manual? If it is a manual, does it blow off if you just bearly touch and let-off the gas? Also, does it seem to stay open for a loooooonnng time?
'04 Dream Cruiser 3 #1132 of 1309
31K miles, 5-speed, H.O. turbo
Mods (so far): Stage 1, Airbox mods, K&N drop in, 3" charge pipe, Mopar BOV, Magnaflow 2.5" catback.
Wanted Mods: Upgraded intercooler piping, A-pillar pod and guages, who knows what else.
  #23 (permalink)
Old 13 May 2008, 08:31 pm
nevinsrt's Avatar
Post Re: Mopar BOV
its an Auto with Autostick
when in boost the surge valve shouldnt open because the throttle body
is still open and air is still entering the engine.
On a manual yes it should bearly bleed off when you let off and it should only open long enough to vent or recurclate. and how long its open is limited to how long it takes you to shift or when it finishes venting.
the longest it should take is around 2-3 secs
if its staying open longer then either you have a boost leak or you have a week spring.
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
  #24 (permalink)
Old 13 May 2008, 08:40 pm
dc3_1132's Avatar
I haven't tested it for a leak yet, (still making my leak tester) but I am thinking it is leaking around the BOV. The car just doesn't seem to pull as hard now that I installed the BOV.
After I did the airbox mods and installed the 3" charge pipe, the car would pull pretty strong all the way up the RPM range. I could actually be cruising along is 2nd gear and start rolling in the throttle and when the boost built up it would start to spin the tires. Now it won't do that. When I roll into the throttle now, it starts to pull pretty good, then seems to flatten out.
  #25 (permalink)
Old 13 May 2008, 08:46 pm
nevinsrt's Avatar
Pull off the Plate and coat the gasket with RTV (both sides) and reinstall it.
and let it dry for a few hours, to help speed up the process you could do it in the evening and then let the car idle for a few minutes and let the engine warm up to operating temps and that will allow the RTV to cure a little faster.
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
  #26 (permalink)
Old 13 May 2008, 08:50 pm
nevinsrt's Avatar
Also have you installed a Check valve on the car.
if not Bwoody sells them for around $30
the stock engine comes with alot of boost leaks
the check valve seals up one major boost leak and cuts down
on blow by. the blow by shows up in the stock airbox or inside the turbo
and intakes with a vac line into the valve cover.
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
  #27 (permalink)
Old 13 May 2008, 08:52 pm
nevinsrt's Avatar
before you do your boost leak test you should zip tie all your vac lines
you should do it even whether or not you do the test.
it helps close potental leaks
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
  #28 (permalink)
Old 13 May 2008, 09:14 pm
dc3_1132's Avatar
So, just by my description of what the car is doing, it sounds like a boost leak to you?
  #29 (permalink)
Old 13 May 2008, 09:18 pm
nevinsrt's Avatar
yes thats what it sounds like
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
  #30 (permalink)
Old 13 May 2008, 09:19 pm
nevinsrt's Avatar
another thing if you have a boost controller
take it off when you do a leak test
the boost controller is an induced boost leak.
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
vB code is On
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
Mopar's Speedshops Announced skylight PT Cruiser News and Rumors 6 06 Nov 2003 01:24 pm
Mopar Parts Now Available For Dodge SRT4 skylight PT Cruiser News and Rumors 5 10 Sep 2003 10:33 pm
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
  Charity | Phpnuke Database | Loans | Secured Loans | Free Advertising
