the SRT-4s like throwing CELs and the S1 PCM fixed it. make sure you get a 3in 02 housing with the downpipe the cruiser motor mounts are the same as the SRT-4 so you could buy Motor Mount inserts and that will stop any wheel hop if theres any and help put more power to the ground. a really good investment and then you could go back to the Bwoody site and get the trans mount. if you havent already done plugs and wires go with NGK 4306 and gap them to around 32 and get some 8.5-10mm wires and that will improve engine responce you could also get a dremil tool and port you throttle body yourself and that will help your throttle responce. saves you from buying a bigger throttle body.
Nevin. 03 SRT-4 68 Mustang Coupe 05 GT Cruiser H.O. — 245hp/283tq @ 15psi 3 in intake, 2.5 in catback exhaust, Stage 1 PCM, Mopar bov, Stage 2 WGA, Check valve, 180 deg T-Stat, Ngk 4306 plugs, 10mm spark plug wires, Energy Suspention MM inserts, upper/lower hardpipes, hawk hp+ front/rear pads, Drilled/slotted rotors, steel braded front lines, Mopar 26mm Swaybar, energy suspention swaybar bushing, energy suspention swaybar endlinks, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Kobalt catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge, APC Non-turbo strut bar, 3in DP, 3in O2. waiting to go on 3in stright pipe, ported turbo, 682cc |
Yeah, I know I need to get better plugs/wires.
I went to the BWoody site and looked at the check valve. It said it is for a SRT-4 Neon. Will it still fit the PT? I have been out of the turbo game for a while so I am playing catch-up. (had a 1986 Daytona Turbo Z several years ago) I have been throwing around the idea of getting a turbo kit for my daily driver SOHC Neon for about a year now, and now that I have the DC3 and started tinkering with it, I REALLY want to turbo the Neon. ![]()
**Dream Cruiser 3 #1132 of 1309** 31K miles, 5-speed, H.O. turbo Mods: Stage 1, Airbox mods, K&N drop-in, 3" charge pipe, Mopar BOV, Magnaflow 2.5" catback, MSD coil & 8.5mm wires, NGK 4306's **2003 Electric Blue PT-GT** 47k miles, auto w/autostick, H.O. turbo Mods: Airbox mods, K&N drop-in, 3" charge pipe, MSD 8.5mm wires, NGK 4306's, more to come!?!?! **2000 Dodge Neon 5-speed** Mods: CAI,MSD coil,Mopar plug wires,Automatic throttle body upgrade,Dual outlet muffler,17" Axis wheels w/Kuhmo tires, Altezza lenses |
but when you install the check valve replace the plastic line with rubber 3/8 fuel line. it makes a snug fit.
Does the check valve replace or just get installed close to the PCV valve?
it gets installed close to the PCV valve it doesnt replace it.
Sorry for all the stupid questions. Like I said I haven't had a turboed car for several years. I had my Daytona turbo before turbo's were "cool"
![]() Once I get my S1 installed and get my A-pillar gauge pod ordered so I can install my SRT Autometer boost gauge, (also looking at a air/fuel gauge) would upgradeing the wastegate actuator give me much more power? I know it will let me produce more lbs of boost and stay in boost longer if I change the wga. Should I run a boost controller if I change the wga?
if you upgrade the WGA you need to get bigger injectors and a Wide band O2 if you run too much boost you'll run lean and the gauge will help you manage you car. you wanna keep an A/F of around 12-12.5 a good WGA to use is an AGP or an S2 the S2 you will have let it stay on PCM control the AGP you will have to take it off PCM control in otherwords by pass some selionds the stock turbo loses its efficiecy at over 22 psi but the stock turbo is too small and wont hold more than 11-13 psi at redline a good goal is to get the car to hold 15 psi till about 5200 thats were the HP and TQ cross then you can add a BC and turn it up more, the BC is just for spike it wont hold boost for long but it will allow you to jump hard on others.
Well, I put some of the copper rtv on the gasket for the BOV yesterday. I just took the car out for a spin and it is back to wanting to spin the tires in 2nd gear when the boost kicks in, but it still doesn't feel as strong as it used to. I guess I am just getting used to the power?
I still can't wait to get my S1 PCM in the car!!!! ![]()
did you put it on and go, of did you let it dry first???
| part numbers | Punch | General Turbo Discussions | 5 | 13 Jan 2004 11:46 pm |
| Mopar Press Release - 11/04/03 | skylight | General Turbo Discussions | 15 | 24 Nov 2003 05:01 am |
| Mopar's Speedshops Announced | skylight | PT Cruiser News and Rumors | 6 | 06 Nov 2003 01:24 pm |
| Mopar Parts Now Available For Dodge SRT4 | skylight | PT Cruiser News and Rumors | 5 | 10 Sep 2003 10:33 pm |
| SRT-4 Mopar Performance Parts | skylight | PT Cruiser News and Rumors | 13 | 23 Jul 2003 07:26 pm |
