How to stop wheel hop?
Old 23 Jul 2003, 09:29 am
Default How to stop wheel hop?
Wheel hop has become a huge problem for me since I've raised the car's power, especially since I've added wider and stickier tires. I've tried varying launch RPM's to no avail. Does anyone have a solution or know of harder engine and transmission mounts that might help?
[xx(]
Old 23 Jul 2003, 11:42 am
i put 245/40/r18 and my rims are 18x8" ,that helped me considerably. Though i have an auto, and i launch about 2500 with very little spin, but i have no hop anymore. I know there are alot of you that have much more experience than i do, but thats my .02$
GSH- how much power are you putting down?
you can view pictures at http://fototime.com/inv/E499E845E668AFF
kruzzinpt
Old 23 Jul 2003, 01:46 pm
I would referr you to PVOs post on beefing up the motor mounts (with 3M Windoweld)....I think that MP is now making a set for the SRT-4.
Old 23 Jul 2003, 02:12 pm
That and slipping the clutch in first.
\'03 Inferno Red 5 spd. Hurst shifter,Loaded
Old 23 Jul 2003, 02:19 pm
Heres something you can try.Remove one of you motor mounts. Buy a polyurethane cutting board, and place the mount on top of it. Trace the shape of the mount onto the board and cut it out, you will probably need a jigsaw or something of the sort. You will need two for each mount. After you have the pieces cut out, place them on either side of the mount and reinstall.
90 Eagle Talon Tsi AWD - 300 Hp -K&N, 16g turbo, JE pistons, 3in Turbo back exhaust, mild port&polish
03 PT Cruiser GT - 215 Hp-Airbox and Intake pipe silencers removed
Old 23 Jul 2003, 06:56 pm
You have to look at your launch technique. If you're just dropping the clutch, you aren't getting your best times. The more spin/noise, the slower you go. If you aren't doing it already, try slipping the clutch in first while launching.
Try reving to just around 2000RPM, then slipping through first; to avoid excessive spin. Also, to improve your 1/4 times, try power shifting. I've found it works very well with this engine/tranny combo.
My Cruiser is slow. I love the law.
Old 23 Jul 2003, 07:09 pm
Looks like you will be the guinnea pig on how well the Getrag tranny holds up to abuse [8)] [^]
Old 23 Jul 2003, 10:32 pm
Thanks for the advice guys. I rarely drop the clutch, choosing instead to slip the clutch while launching at 2000 rpm. The problem is the friggin tires tend to break loose before I power shift. Once the break loose, its wheel-hop city until I back off, and then it's all over. My Firehawk SZ50's are infinitely better than the stock Goodyears, but until I solve the wheel hop, my "street sweeping" action is going to be limited.
Looks like it's time for me to start thinking about fabricating solid mounts for the engine and tranny.
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC — The WooX 30w x 2 powered subwoofer
Old 24 Jul 2003, 01:24 am
A limited slip diff wouldn't hurt either.
Old 24 Jul 2003, 02:25 am
Good idea, except the only LSD's i've found so far are those crappy bolt on bracket type things. They snap like balsa (sp?) wood. But, no i don't regularly rip up my tranny, only when it is deemed "necessary". Hell, you have a warrantee for a reason. On my '01 they replaced my tranny at 16,000km, NO QUESTIONS!! And it was modded to hell.
If you're slipping the clutch and your still getting hop, then you're engaging the clutch to much, try slipping a little lighter (ie. taking away more power from the wheels) See how that works out for you.[^]
Mopar PT Wheel Lock Kit 82300160 gtobey Classifieds: For Sale/Trade 0 24 Sep 2004 05:19 pm
MOPAR WHEEL LOCKS KIT 82300160 gtobey Classifieds: For Sale/Trade 0 24 Sep 2004 05:16 pm
New Steering Wheel at Jegs nhrapt Interior Accessories Forum 2 24 Feb 2004 01:03 am
Leather steering wheel maintenance? 2 TONE PT The Detail Shop 6 12 Dec 2003 12:21 am
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
