What's MAX boost...
Old 30 Jul 2003, 06:27 pm
Default What's MAX boost...
I tried a search and couldn't find anything... I know there's a whole lot of people on here running some kind of boost controller. What i want to know is, what is the MAXIMUM amount of boost people are running without throwing codes??? [}]
Old 30 Jul 2003, 09:13 pm
My max has been 13.1 That is in stock trim.
Don
2003 PT GT
Old 30 Jul 2003, 10:02 pm
14 PSI constant with no peak and never a code...
Ian
Old 30 Jul 2003, 11:31 pm
I have read that "The Chrysler PT Turbo's High Output, turbocharged 2.4-liter engine creates 12.9 psi boost, 215 horsepower at 5000 rpm and 245 lb.-ft. of torque at 3600 rpm, with more than 90 percent of peak torque from 2300 to 5000 rpm. Compression ratio: 8:1:1, Max RPM - 6240, Unleaded premium 91 octane (R+M)/2 fuel is recommended. The PT turbocharger is intercooled. It is integrated into the exhaust manifold and has a computer/vaccum controlled wastegate..."
Old 31 Jul 2003, 01:15 am
what i'm getting at is how much can you boost to with a boost controller without throwing codes??
My Cruiser is slow. I love the law.
Old 31 Jul 2003, 08:17 am
Cop Tzer,
I use an A'PEXi AVC-R boost controller and it is settup for 14 PSI With no problems ever. Anything over 15PSI over a prolonged period, the fuel system will dry up and go to a lean condition. Stage I is scheduled to go up to 16.5 PSI with the bigger injectors included in the kit.
My factory settings in the "Auto Stick" where 14 PSI and then drop to 12.5 PSI.
Ian
Old 31 Jul 2003, 01:41 pm
Your MAP and TIP sensors go out of their range at about 16-17 lbs, but guys are boosting to 18lbs. I don't know if I would go over 16 lbs consistently because of head gasket limitations.
Old 31 Jul 2003, 06:46 pm
Thanx guys, I'm gonna spend some serious time at my friends speed shop on Saturday doing installs...we've spent the past 2 days measuring and planning...hello cutom UPP, BOV setup, and MBC setup
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
Boost Question Mel K Turbo Performance 2 04 Apr 2004 09:27 pm
Taking control of the boost Jason_L Turbo Performance 2 03 Jan 2004 10:35 pm
20lbs of boost and no eng lite amx1397 Turbo Performance 6 21 Jun 2003 07:20 pm
