Which mounts did you buy? Spoke to guy at Modern Performance today and he told me the Prothanes will not work on factory PT mounts, only on SRT-4. I was under the impression that the PT and SRT-4 shared the same mounts???
Everyone told me the stock mounts are the same for both of them. I picked up the mounts from NAPA for the PT Cruiser. I then ordered the Prothane inserts. You have to trim the "webbing" between the pieces of prothane, top and bottom on one insert, and just the top on the other so the rubber slides in between them. I got mine to slide in no problem. So, they will work if you get rid of the webbing.
You will see what I mean if you buy them. They work. ~CYCLONE_06 |
Ordered my inserts and bolt kit today
I added red Prothane inserts to my factory mounts and they work great. Also supposed to increase lifespan of mounts. You will still need to replace your factory mounts (assuming they are broken), then the inserts just slide in before you bolt them up. Inserts are $23.99. Here is link:
Modern Performance Racing Products
Mine have been on there for a while now, good so far. ~CYCLONE_06 |
Hey all.
I see that this is an old thread, but my wife's PT's mounts are wearing out causing the symptomatic cabin rattle. We took it to a mechanic and they quoted 1300 dollars to repair it, since they have to pull the engine to get to the lower mounts and that equals almost 10 hours of work. Is it accurate that you need to pull the engine to do this? Why couldn't you just jack the engine up? Should I get a second opinion? |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
I also got the prothane inserts. They keep the rubber webbing from twisting too far from the torque, which is why the original mounts wear out. Best $24.00 i ever invested. ~CYCLONE_06 |
Hey all ..i,m back..Having replace all engine mounts alongside my team wrenchman,we did not have to remove the engine to replace the mounts,but i see that the touque mounts or struts are the weak spot.they are the upper and lower right mounts not the other two mounts.I went with deyemene mounts and should never break the inserts.
If you are replacing the engine mounts themselves make very sure you measure there exact location and make very sure your alignment is perfectly on the money. |
| engine mounts | lt4supr | General PT Cruiser Discussions | 11 | 04 Jun 2008 07:56 am |
| NOISY ENGINE!!! | ncrow02 | Tech & Performance Forum | 2 | 05 May 2008 12:52 am |
| "Mysterious" turbo engine noise...??? | Gary04GT | Turbo Performance | 76 | 21 Aug 2006 08:28 am |
| Review: $2200 for a NA replacement engine PT | Ctown | General PT Cruiser Discussions | 8 | 24 Jul 2006 01:08 pm |
| Engine mounts | KingKole02 | Tech & Performance Forum | 3 | 13 Jan 2005 04:04 pm |
