....from using lower grade of gas than premium???
Withgas prices as they are, I've been using the mid-grade gas lately to save some $. I can tell that there is some loss of HP with the lower grade of gas. On the way home today, i got to wondering, does using the lower grade of gas result in an actual loss of HP or is the decrease in performance due to something else when the timing is adjusted to compensate for less octane. Curious, Bill
BB \'03 Stone White GT ..with a little chrome..so far |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Understood MG!
But.....how much HP loss is there? Anybody know? Bill
BB,
In order to measure HP loss you'd have to put you car on a dyno. Have you ever seen a dyno pull in person. The engine is taken to red line a few times to get accurate readings. Putting a lower grade gasoline in the tank and having the computer retard the timing would mean your redlining the engine in a non-optimal configuration. First a couple of pulls with premium gas to get a base-line reading then again when you use up that gas and fill up with a lower octane gas to find out what you already know. Will it damage anything? Let us know when you try it.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 20 Jul 2008 at 09:37 am. |
As you may or may not know, the only difference between the GT HO 220-230hp and the 180hp "turbo lite' is the PCM, along with the use of the higher octane fuel, the increased hp is from more timing and boost, allowed by the higher octane fuel, along with more fuel by increased injector pulse time, so if you use regular gas as used in the 180hp turbo, the timing is pulled back due to spark knock, along with lower boost levels because of the timing cutback, you will be very close to the 180 "turbo lite" levels, but running rich due to injector programing at WOT, you will still use the same amount or more of gas, but with approx 40 less hp. So you will spend the same amount or more money for the same mpg because of the programming of the PCM. Now if you had the proper programmed PCM you might save a little at the pump depending on your type of driving.
If you had a boost gauge you could the tell approx. the difference, as the "lite" runs about 10 psi of boost stock and the GT HO approx. 14 psi, and it is about 8 to 10hp increase, or decrease for every pound of boost gained or lost.
'05 GT Dream Cruiser Series 4. No.1109 http://www.alcamar.com/mods/ http://www.alcamar.com/dc4 http://www.alcamar.com/trailer/ |
Also, I think another difference between the 180 light and HO is that the HO has larger injectors.
I use Costco gas here in So. Florida. It's 93 octane for the price of mid grade. The attendant there told me the gas is supplied by Amoco. Car runs great, performs grade without any problems.
2005 GT Cruiser, Cool Vanilla, Automatic, Borla Dual Exhausts, K&N, Navigation and U Connect. 2001 Corvette Convertable, Navy Blue Metalic, Z51, 3:15 with 4" inch quad Borla Stinger Exhausts X Pipe and K&N Filter. Last edited by bados; 29 Jul 2008 at 07:09 am. |
Stage 1 only included a new computer from 2004 upwards to prove my point.
| Power loss | littleblueGT | Turbo Performance | 3 | 11 Apr 2006 11:45 pm |
| Intake mod that increases horsepower AND mpg! | Jeff V | General PT Cruiser Discussions | 18 | 06 Dec 2005 11:41 am |
| Power loss | Betsey | General Turbo Discussions | 5 | 10 Dec 2003 03:45 am |
| Mobil 1 oil loss, oil change recommendations | PTGT-NH | Tech & Performance Forum | 9 | 15 Jul 2003 01:27 pm |
| AIRAID for more HORSEPOWER | ipioneer | Vendors & Buyers Forum | 1 | 26 Oct 2001 09:03 am |
