A TRUE cold air intake
Old 02 Aug 2003, 03:07 am
Default A TRUE cold air intake
[8)]As usual the cheapskate in me took over, that and I'm a poor working
stiff!! Ben had an Air Raid, so called cold air intake for a non
turbo. It's metal, FULL of gaps and it's not insulated!! Sooo, I
used it as a template for a REAL cold air intake and it works with
my hood scoop OR the conventional fender vent. It's made from 1/4 "
plexiglass, conforms to the shape of the hood and fender sides,
allmost a perfect seal, I used a radiator hose that was the right
shape and insulated the hose and the box with thin foam and aluminum
insulation. The temp difference between the box and just outside is
approxamatley 75 degrees!!! Needless to say the performance boost is
signifigant!!AND I reworked the hood scoop and insulation so it
works perfectly with the cold air intake. Note the blue insulation,
brake paint!! Also It took a BUNCH of tries but I finally got the
pattern right for the battery cover!! go to my photo album @ http://photos.yahoo.com/bc/airbillster and see
Prototype to finish. Tommorrow I do hood struts and
finish the hoses!!!!
Old 03 Aug 2003, 12:18 am
I'm not able to see in your photos where the cool air comes from. Still looks like it draws underhood air. What am I missing?
Joe
USA- Love it or Leave it!
Old 03 Aug 2003, 12:24 am
Send a message via AIM to ptcruzin42
how much would charge to make one of these for someone?
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 13 Aug 2003, 12:59 pm
[8)]The outside air has 2 sources, 1 from my Lund hood scoop and 2nd from the fender vent
To seeem all go to
http://www.imagestation.com/album/?id=4289487969
Bill Seat
Founder - Route 66 PT Cruiser Club
http://www.route66ptcc.org
Va. Director - PT Owners Club
703-597-5354
2003 Electric Pearl Blue Flamed GT Turbo
Stage 1 equipped
Old 13 Aug 2003, 01:10 pm
Actually I'm working on a 3" insulated tubeing from the cone filter(opening in filter) to the 2.5" opening at the turbo!! I've finished the new box design (will post) and will have the tubeing finished this weekend. All plexiglass and PVC...
Pricing, I'm working on it!
Oh!! The Battery cover is $40 plus shipping
Bill Seat
703-597-5354
Stage 1 equipped
Old 14 Aug 2003, 12:07 pm
I'm all for some sort of battery containment. I have had 2 batteries explode on my automobiles. One in a containment box, and one not. Without the box EVERYTHING gets soaked in acid, with, it's a simple matter of getting a new battery. With the heat that collects in our engine compartment I am supprised that the issue of battery explosions has not come up.
(For those of you that are not familiar with this issue, battery acid when heated gives off hydrogen gas, which is very explosive. Even a small ammount is enough to break a battery case and spray acid all over the engine electronics. After an explosion every connection is suspect, every crevice that water and acid can enter is a place for long term mayhem.)
Old 14 Aug 2003, 01:16 pm
[8)]Finished, Redesigned plexiglass insulated box and 3" PVC insulated to the turbo opening 2.5"BEFORE
After [?]
Bill Seat
703-597-5354
Stage 1 equipped
Old 14 Aug 2003, 01:19 pm
Original used 2" radiator hose to the 2.5" opening...
Bill Seat
703-597-5354
Stage 1 equipped
cold air intake or modified air box? pppt03turbo General Turbo Discussions 17 21 Jan 2006 01:11 am
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
The only TRUE Cold air intake!! Airbillster Vendors & Buyers Forum 4 28 Nov 2003 12:06 pm
Real cold air intake Airbillster Tech & Performance Forum 5 02 Sep 2003 02:26 am
"True" Cold Air Intake by INJEN... Gary04GT Turbo Performance 17 12 Jun 2003 02:50 pm
  Christmas Ecards | Real Estate Articles Directory | MySpace Layouts | Debt Consolidation | Child Support Explained
