You should look for boost leaks. If you needed a BC to get to 10#'s there is something wrong. You would love the feel of full boost.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
LOL! Ok, so, like my brothers car. Wideband, o2 sensor, bigger injectors, from stock cc to what cc? Boost controller. Then I can start cranking some boost.
You will never see 20psi, its beyond the stock turbo its out of breath at that pressure.. 18 is about the max for it - per one of the engine designers. And if you need more than that on the street you have issues. That 18psi will keep just about everyone going "WTF??? A PT????" And just FYI in an Auto you should not be boosting in O/D aka 4th if you want to keep your trans in one piece.. Always drop to 3rd then hammer it..
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though ![]() My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life. |
from everything I have read on several forums, Stage 0 can be pushed up to 15psi with a MBC and or adjustable wastegate. Anything over that will throw an over boost code. More boost requires a staged setup. I.E. stage 1 and up and including the required parts for each.
O4 GT 5 speed, Electric blue pearl. LOADED.http://www.cardomain.com/ride/3305579 |
'03 GT Autotragic Drag Stats! R/T .252 1/8 Mile 9.644 @ 72.92 1/4 Mile 15.009 @ 93.50 Mods! Intake Box Removed 3"F 5"R Lowering (Thanks Candyman) 19" ASA JH9 w/215/35/R19 General's Traded (04-14-2010) '06 Mustang GT Autotragic Drag Stats! R/T 6.107 (Waiting on the wife's smart car to get a head start ;P) 1/8 Mile 9.152 @ 78.36 1/4 Mile 14.202 @ 96.69 Car Team Website: Insufficient Boost [iB] |
You get a few quick benefits. 1. Better airflow across all 4 cylinders 2. Lower under hood temps since the plastic doesn't hold heat like the metal 3. You loose a little weight swapping out the metal parts for the plastic. Manifold upper/lower and support bracket - 10lbs. Not much but something. 4. You can still change your spark plugs through it, though it does require a craftsman(its shorter than others) spark plug socket with a knuckle on it. The spaces between the runners are tighter than the metal manifold, but its doable. 5. Optional - you get a great spot in the back of it to tap for water injection, NOS.
I know of the manifold swap. I was talking about the intake housing of the actual turbo. You take the intake housing off of the stock one and bolt up a larger diameter intake housing. I search on google for about 15 minutes to try to find it again...and go figure...can't find it now.
| Final manual boost controller installation | Ian-PT-GT | Turbo Performance | 85 | 05 Mar 2010 03:04 am |
| $5 BUCK BOOST CONTROLLER! | MARKS-GT | Turbo Performance | 24 | 06 Oct 2006 04:46 pm |
| Turbo XS Boost Controller With Adaptor | blueberrygt | Classifieds: For Sale/Trade | 2 | 08 May 2004 06:08 pm |
| Boost Controller Versus PCM | FRM3 | General Turbo Discussions | 3 | 08 Oct 2003 10:59 pm |
| Boost Controller and Gauge Questions | Dalite | Turbo Performance | 13 | 14 Jul 2003 01:20 pm |
